Old 07-30-2007, 02:45 PM   #1 (permalink)
mikecarport's Avatar
Default p38 leaking coolant, help.
i have a 96 4.6 hse. last november i had the water pump replaced and haven't had any problems since. other than it will run a little warm in the florida heat. until now...
sitting still with the engine off it holds coolant just fine. i'll crank it up and let it run until it hits a normal running temp, no problems there. then it seems it would hit a certain temp and then start pissing coolant, so i thought thermostat. i replaced it but i am still getting the same prob. i drove it to work this morning and the coolant held fine until i shut off the truck. i'm having a real hard time tracing the leak. it is dripping from the rear of the oil pan.
any advice, or anybody have a similar problem? thanks for any help.
'64 series IIa 109 5 door (i love this damn truck)
'96 Range rover
mikecarport is offline   Reply With Quote
Old 07-30-2007, 06:55 PM   #2 (permalink)
intake gasket, AKA valley pan gasket normally leaks at the back where it cannot be noticed and then runs out over the bell housing onto the ground.
good luck.
carlosz
carlosz is offline   Reply With Quote
Old 07-30-2007, 07:08 PM   #3 (permalink)
also check under the passenger side of the dash for the heater core orings.
Old 07-30-2007, 10:13 PM   #4 (permalink)
P38 stole my money
kmagnuss's Avatar
Also check under your throttle body. There's a gasket there that will leak eventually. It'll leak onto your driver's side valve cover. Sometimes leaves a pink dry residue build up.
2000 Rhino
Did you work on your P38 today? I know I did.
kmagnuss is offline   Reply With Quote
Old 07-31-2007, 07:23 AM   #5 (permalink)
Elemental's Avatar
I wonder if the hose recall was done.
Ironically, that recall alos replaces that Jarvik 7 Looking thermostat.
Old 07-31-2007, 09:32 AM   #6 (permalink)
i replaced it with this one.
http://www.roverparts.com/Parts/PEM101130.cfm
does it sound like the thermostat could still be the issue.
'96 Range rover
Old 08-27-2007, 10:05 AM   #7 (permalink)
i fixed it. it turns out it was a little 90 deg hose behind the water pump.
'96 Range rover
