Old 04-20-2005, 12:15 PM   #1 (permalink)
Default P38 rear wiper problem
Hi guys, anyone ever worked on the rear screen wiper?? Mine has come loose, & is hanging down,I can't see how to re-tighten it, not much room to see/work under the top skirt. c'mon, tell me how to do it!!
I DO have to grow old, I DON'T have to grow up!!
modelman is offline   Reply With Quote
Old 04-20-2005, 06:14 PM   #2 (permalink)
Mr Tj's Avatar
Not sure how much help this is, but the vehicle manual has some rather odd description for how to change the wiper blade.
Basically you have to turn on the back wiper (ignition on, wiper stalk pulled back, etc), then cut the ignition switch when the wiper is half-way down the tailgate (ie close to vertical).
At this point it's possible to lift the wiper away from the glass and do any work necessary.
Obvious design, really...
Staffan Tj
'96 RR 4.6 HSE NAS
125k
Rioja Red, Walnut
Mr Tj is offline   Reply With Quote
Old 04-21-2005, 10:38 AM   #3 (permalink)
Thanks for the swift reply, but I got it wrong, its not the wiper, but the arm, sorted now, found that if the arm was pushed up under the 'skirt', the plastic nut-cover could be slid back to reveal the spline-nut, this was then tightened, all is well again!!
Old 04-21-2005, 10:50 AM   #4 (permalink)
troverman's Avatar
It is also a good idea to take the whole assy. out, take the motor and gears apart, and lubricate! On my car, it was extremely slow and finally stopped. Really pretty easy to take the whole thing out and do. Its important that it works right because it comes on in reverse automatically when front wipes are on.
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
