p38 warning light, 'IGNITION KEY STILL IN" - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 2 (permalink) Old 03-06-2009, 02:08 PM Thread Starter
Quoted: 0 Post(s)
Does anyone know what this is, when I take the key out it says it's still in!
Dr Murder is offline
post #2 of 2 (permalink) Old 03-07-2009, 11:14 PM
Quoted: 0 Post(s)
If you keep getting the "IGNITION KEY IN" message when the key is not in, the BeCM thinks the key is in the ignition and is thoughtful enough not to let you remote lock the vehicle in case you lock your keys in. The microswitch that detects whether the key is in is probably staying in the "in" state because of the center of the lock barrel being a bit sticky. Often, just pushing on the center of the lock barrel will cause it to pop out, fixing the problem. Otherwise, just try reinserting the key and wiggling it in and out a bit to free up the mechanism. Alternatively, you might try puffing (with an applicator) graphite powder into the lock. Usually it will free itself up -- this is much cheaper than buying a new lock!
eurodmguy is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Funky Trans Warning Light Street Wolf Discovery Series II 0 02-08-2009 02:34 PM
Ignition warning light staying lit msport Range Rover Classic 5 04-18-2007 08:01 AM
Disco II Oil pressure warning light mcenery Discovery Series II 3 02-01-2007 01:46 PM
Ignition Warning light on, tach working 92rrcl Range Rover Classic 2 01-17-2007 09:14 AM
brake warning light? nid Series Land Rovers 1 01-18-2006 07:18 AM
You may post new threads
You may post replies
