Old 04-07-2005, 10:47 AM   #1 (permalink)
troverman's Avatar
Default P38a-rear passenger door lock not working
The power door lock was working fine, then it stopped working altogether--plus no interior lights come on when i open that door, and the alarm doesn't go off if the door is opened when the alarm is armed! It was working fine--and then two minutes later it wouldn't work at all. What's up?
On another note, the pass front side lock button stopped locking the whole car when it is pressed or pulled up, as it usually does. However, that happened maybe a month ago and the rear was still working fine, plus that lock still worked with the central locking system.
Any ideas?
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
Old 04-07-2005, 02:02 PM   #2 (permalink)
Default Could it be the becm?
Could it possibly be the body elctronic control module? A hook up to a diagnostic computer would tell if so.
mafpolo is offline   Reply With Quote
