Old 06-28-2008, 08:56 AM   #1 (permalink)
Default Passenger Window Makes Clanking Noise Once fully Up
Got in my 1998 range rover yest and my little cousin was sitting shotgun. He was raising the window in the truck and after it was fully up it made a loud clanking noise. It sounded like the window didn't know it was all the way up and it was trying to close even more , but it couldn't because it was fully up.
Can someone please tell me what they think the problem could be. I dont want to mess the motor up . thanks
BlackRR is offline   Reply With Quote
Old 07-03-2008, 08:12 AM   #2 (permalink)
hermanpj's Avatar
Gallery: 4
i have similar issue. you probably got a warning in the display that the window is not set as well...
do you get one clank, or will it make multiple clanking noises rapidly in sequence? what appears to be happening on mine is the lift motor keeps turning after it should have stopped. there is an arc of metal with gear teeth cut into it which the motor's gear meshes with, and it would appear that some kind of stop or limiter for that arm has broken off. i have not extracted the regulator to check it out bc i havent had the time - you have to pull out the window first. so im not sure if this can be repaired simply or will in fact require a new window regulator. let me know if you find out anything
Pat Herman
Passenger Window Makes Clanking Noise Once fully Up BlackRR Range Rover P38, Mk III and Range Rover Sport 0 06-28-2008 08:49 AM
window not set plus bad noise hermanpj Range Rover P38, Mk III and Range Rover Sport 10 11-01-2007 01:53 PM
passenger side window scotth Discovery Series II 2 08-13-2007 04:40 AM
Window noise Rebelman Discovery Series I 5 12-05-2006 03:55 PM
Draft from rear passenger window Frosty_Power Discovery Series II 3 01-28-2005 03:24 PM
