I have read your postings on the 2001 Range Rover Check Engine Light
I have a 1999 4.0 Land Rover that is giving me these codes I had the P0305 misfire code and replace all spark plugs and spark plug wires I still had the code I just replaced both heads because of lose valve guides and though that would solve the problems. The valve guides were in bad shape. Prior to the replacement I had the P0305 misfire cyl 5 code Now I have these I clear the codes. The engine runs fine until about 2400 rpm under load and no load and the I get these codes. I feel the engine miss and the MIL light flashes P0137 O2 Circuit low voltage (bank 1 sensor 2) P0305 cyl 5 mis fire P1319 Misfire with Low/Empty fuel drive cycle C: signal out of range. Above Max The dealer told me it was a slipped sleave in the cylinder. I have no coolant leaks and no coolant in the oil. I have no oil leaks. What next. Coil? O2 sensor. I have a good OBD that has freeze data gathering. any ideas, I love this car |
| Thread Tools | |
| Display Modes | |
| I need help buying a Range Rover | bmilcetich | General Land Rover Discussion | 10 | 08-29-2008 06:38 PM |
| 2001 Range Rover HSE Check Engine Light | umoms | Range Rover P38, Mk III and Range Rover Sport | 21 | 05-02-2008 04:53 PM |
| 2008 Land Rover Range Rover review | torres | Range Rover P38, Mk III and Range Rover Sport | 0 | 07-30-2007 08:31 AM |
| 1999 Land Rover Range Rover 4.0 SE V8 Cylinder 4.0 Only $7500 | sky2you | Land Rover Vehicles | 0 | 06-19-2007 06:37 PM |
| 1999 Discovery Light bulb guide | darkknight1999 | Accessories | 3 | 03-22-2006 09:31 AM |
