My co-worker is test driving a 96 4.6 hse over the weekend and the air ride will not work at all. He isn't dying tokeep it either. Is there some type of coil spring conversion he can do if he decides to buy it? What are some problem areas he needs to look at before buying? I noticed under the front/bottom of the engine there was a mass amount of oil caked up around what looked to be the oil pan where the oil filter is. Checked the oil and it was fine, maybe the problem is fixed? Thanks for any help!
David |
LRO Founder
Yes you can convert to coil suspension rather easily. You really should go to www.rangerovers.net as they have a great section on common problem areas with these vehicles. Take a look there, it is a great resource.
Serg
Current Vehicles: 1995 Range Rover Classic LWB in Beluga Black 2005 BMW R1200GS 2004 Element Skateboard (Indy trucks, Bones Swiss, etc...) Past LR's: 1995 Range Rover LWB Classic 1997 Discovery XD 1995 Range Rover LWB Classic 1995 Range Rover LWB Classic 4.0 |
LRO Founder
Well if you have tons of money to pour into air suspension repairs, then by all means keep it. The Rover I bought had a brand new air suspension put in less than 3 years ago and that completely failed last year. The PO replaced it with coils.
Serg
#5 (permalink) | |
Dave '98 Range Rover 4.0 '94 Discovery '69 Series IIa 88" Last edited by Dave : 08-24-2004 at 04:13 PM. |
I read your post about the Rangie your co-worker is looking at. Coil Springs are very expensive to install and take away from the resale value in my opinion. It kind of gives the impression the car has something wrong with it. If the EAS is not functioning in this particular vehicle, you may be able to pick it up at a substantial discount. You can figure about $2500 to completely replace the EAS components at a Land Rover dealership which will give a 12 month / 12,000 mi warranty on all the parts and labor.
From my personal experience with a tempormental EAS system on a 1996 Rangie, I developed a simple solution to a faulty EAS system. The system allows the air springs to be manually inflated using a tire pump. The system will hold air as long the air springs and air lines are good. It restores drivability to the car and gives the owner an opportunity to save the funds for repair or go another route. I sell these kits online at www.carrollrovers.com. Check it out, it may be exactly what your co-worker needs. Regards, Justin Tiemeyer www.carrollrovers.com 1996 Range Rover 4.0 |
