Old 03-06-2005, 10:35 PM   #1 (permalink)
Default Removing roof rack
Does anyone know how to remove the factory roof rack?
I have a '02 RR and it looks like there are some funny hex screws with a pin in the middle holding it down.
rsholanki is offline   Reply With Quote
Old 03-07-2005, 06:11 AM   #2 (permalink)
Default Whole thing including the rail?
If you are removing the whole thing with the rail, it might need rubber grommet to patch the whole in the roof.
I once removed roof rack from 97 Disco I and bought 2" rubber grommet and plugged the hole for the rack on the roof.
AdrianL is offline   Reply With Quote
Old 03-07-2005, 02:40 PM   #3 (permalink)
Do you know of any sources where I can get the hex tool to remove the screws on the base? I lost mine.
Old 03-08-2005, 06:42 AM   #4 (permalink)
Default Security Hex nuts
I believe those are the security hex nuts or bolts used to prevent theft. You can get a set from AUto Zone or also I have seen from Sears Craftmand Catalog also. I believe these have a little hole on the center of the socket to fit in the bolts with pin.
Old 03-08-2005, 06:59 AM   #5 (permalink)
troverman's Avatar
'02 Range Rover. Is that a P38 (the last year they were made) or an L322 (if you don't live in the States?
P38 uses those integrated into the roof design.
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
1982 Volvo 240 GL Diesel
Previous Rovers:
1995 Range Rover 4.0SE
