» Sponsors
» Sponsors
Old 04-26-2006, 01:21 AM   #1 (permalink)
Default Replacing heater o-rings and servo
Any ever attempt to replace a worn out servo and heater o-rings on a 99 Range Rover? I was wonder how difficult it is removing the various dash and console components?
gbvilla is offline   Reply With Quote
Old 04-26-2006, 06:24 AM   #2 (permalink)
02RhinoRange's Avatar
Location: Nashville,TN and Chattanooga/Dayton/Knoxville for play....
Not sure how the Gems/Bosch engines differ behind the dash, if they do at all, but there's a shortcut where you don't have to remove the dash.
You open your glovebox, drill a hole in the side of your glovebox which allows a long screwdriver to reach a hidden screw that allows access to the o-rings...
Do a search on RangeRovers.net there's plenty of info in the threads on there...
But in the meantime:Heater O-Ring repair
'02 Range Rover Rhino ed.
Warn XD9000 w/ factory winch tray
RockRover diff guard, RockRover sliders
Safety Devices roof rack
255/70R16 Pirelli Scorpion ATs on 16" DII alloys
255/55R18 Nitto 420S on 18" Proline wheels
'95 RRC LWB County
Coil conversion w/ OME shocks, AB springs
02RhinoRange is offline   Reply With Quote
Old 04-28-2006, 03:05 PM   #3 (permalink)
Sailcnc's Avatar
Default " O Ring Replacement"
I just did this. The servo may be an issue. The O rings were a piece of cake. You will have to remove the side pannel on the center console. The passenger side only. You will drill a small hole on the inside of this piece. This will enable you to remove the screw holding the vent in place. You will then need to remove the glovebox lock and use about three extensions and loosen the bracket holding the heater matrix pipes in place. You can then replace the O rings. There is a good description on the web for all of this.
Joe
Sailcnc is offline   Reply With Quote
Old 05-11-2006, 05:52 AM   #4 (permalink)
Hi Joe is yours a Left Hand Drive car? as I thought the O rings were on the Right Hand Side of the heater unit?? so for a RHD car you need to remove the drivers side to access ??? or with your long extensions were you able to go round the back of the heater unit - confused...
Stopover is offline   Reply With Quote
Old 05-15-2006, 02:08 PM   #5 (permalink)
Default it is simpler than the traditional way ..
Shortcuts to O-Ring Replacement Procedure
The official O-ring replacement procedure outlined in the shop manual is to devote 12 hours of labor (by you or the dealer) to removing the entire dashboard and center console, disconnecting the air conditioning, disconnecting both airbags, and pulling the steering column. While this procedure is necessary when the entire heater core needs replacing, alert readers have found shortcuts which greatly ease the pain of the operation and avoid massive dismantling of the dash.
As the heater O-ring connection is under the right-hand side of the dash, it is a fairly inconvenient fix for RHD vehicles owing to the steering column and other stuff under the dash. For LHD vehicle owners, it is easier (see below) as there is only the glove box and transmission hump side panel to remove. Ron Beckett of Australia has supplied the following details on how to replace the O-rings in a RHD Australian 4.6, after he noticed a bit of leakage onto the carpet, apparently triggered by disturbing the fittings whilst replacing all the water hoses. We are also extremely grateful to David Sparkes in the UK for the initial advice, especially where to drill holes, and photos (not reproduced here) on how to remove the ducting in order to access the blend motors (another page in preparation!). Note that the basics of replacement don't change for a LHD car, it's just that you may have more access for your hands - which makes it easier.
An alternative method of accessing the O-rings is removing the dash -- this operation is described on the Dashboard Removal Page.
Once you have everything apart, Ron also highly recommends you replace the Core Temperature Sensor at the same time. The sensor clips onto the lower heater pipe and is very easy replace whilst you have the car apart. It is a common failure item and if you have the TestBook symbol appearing on the HEVAC display, followed by it having cleared at next start up, there is every chance the sensor has failed. It's not cheap (about US$30, A$50) but it's probably still worth doing. It probably also affects the operation of the air conditioning as it provides information about the water temperature to the HEVAC system - so it's better that it works properly.
O-Ring Location and Access
The O-rings are located on the right hand side and above the transmission hump - actually just above the RH footwell air vent. In fact, if the O-rings are leaking, you often find tell-tale white residue from the coolant in, or around, the vent - see photo below. To get access to the O-ring connection requires that you will have to remove the large lower fascia under the steering column (RHD vehicles), and the RH side panel on the centre console. Ideally, you need to remove the instrument panel as well to gain access to the upper end of the ducting. The workshop manual tells you to remove the complete fascia (dash) assembly - officially a 12 hour job but reduced to 6 hours (including removal and replacement) using the procedures described on the Dashboard Removal Page. Thus, the method to be described below is much quicker. A lot of this work is also required if you need to replace the distribution or blend flap motors (see blend motor replacement page) - another job which LR say requires removal of the fascia assembly.
Start by removing the RH side panel - see the page on Removal and Replacement of the Side Panels.
With the side cover off, you now have access to the lower air vent and duct. The outer vent outlet just pulls off. The inner vent outlet is retained by two screws, one of which also holds the air duct in place. Remove these two screws. Note the white residue on the heater matrix above the vent where the coolant has flowed down. Unfortunately, the residue on the vent itself had been cleaned off before the photo was taken.
Above: Pull off the outer vent and ... Above: Remove the two inner vent retaining screws.
The air duct which runs from the screen down to the floor is further retained by a screw hidden behind an inner panel. You have two options: (a) pull on the duct to break off the mounting lug or (b) drill a hole through the inner panel to access the screw. This hole will be covered when you refit the side finishing panel removed earlier. The photo below shows where to drill the hole to access the hidden screw.
Above: Drill a hole here to access the hidden screw behind... Above: Stay Tuned!
At this point, the access procedures diverge for the LHD and RHD vehicles - but this section deals with the additional access for RHD vehicles. In this case we need release the top of the duct to allow it pivot out of the way at the bottom. This will become clear when you do the job. To do this we have to remove the instrument panel. It may not be strictly necessary to do this but I didn't feel comfortable with flexing the lower heater duct out of the way to get to the O-ring heater connection screw.
So for RHD vehicle owners, we refer you to the instrument binnacle removal page - see Removal and Replacement of Instrument Panel
Return to Top
Removal and Replacing of the Heater Ducts
Removal
After pulling out the instrument panel, you will now be able to access the top of the heater ducts. These ducts connect the heater to the upper outer dash vents and to the floor vents.
Referring to the pictures below, slide the intermediate joiner to the right to disconnect the inner duct from the outer duct. This will allow the inner duct to be separated from the heater and swung away at the lower end near the heater matrix. It will require quite some flexing of the duct to get it out of the way - but it can take it the flexing.
Above: Slide this intermediate joining piece right to.... Above: .... disconnect the inner and out ducts.
Removal and Replacing of the O-rings
Removal
Above: Pipe connector to heater matrix.
Below: The pipe clamp released. You can just make out the edge of the O-ring on the lower pipe.
Above: Another view of the heater pipe attachment. Note just-visible phillips head screw which has to be removed to release the pipe clamp (see below left). That blue item is the connector to the heater core temperature sensor which is clipped over the heater pipes and which often fails.
Below: Heater core temperature sensor mentioned above.
Abbreviated Procedure for Left-Hand Drive Models
Thomas Dirksen found a much faster way to replace the O-rings when coolant started leaking into the cabin of his US-spec 4.6 HSE, saving $1,000 in labor. He removed the glove box and was able to loosen the screw holding the O-rings by going through the glove box lock hole. This procedure took about 3 hours.
Thomas bought two O-rings from the dealer for $10. Then he removed the glove box and panels and the glove box lock. Looking inside the lock hole you can see the single screw that secures the O-rings. He used about 16" worth of 1/4" drive extensions, with a universal joint, to reach the philips screw. He secured the bit and the socket with 3M high strength adhesive so they would not fall off while trying to loosen the screw. Once the screw is loosened the heater pipes disconnected very easily and were very accessible where the glove box was removed.
To install the new parts, he cleaned the crust off the pipes where the coolant had been leaking, and lubed the O-rings with coolant. The philips screw was damaged during removal, so he replaced it with a hex drive machine bolt of the same thread pattern, complete with locking and flat washers. He used the 3M high strength adhesive to temporarily bond the new screw to a hex drive bit. He managed to insert the screw into the hole, and when it was sticking out on the other side by 1/8" he placed a drop of Loctite on the exposed threads. He pushed the O-ring fastening bracket on to the bolt and tightened the bolt down all the way. The leak was gone!!!
Simon Goode confirms the effectiveness of this technique. The only snag he struck was: "When trying to undo the screw I rounded it out and had to end up cutting a slot in it with a hacksaw blade to fit a blade head driver in. Then when I attempted to undo it the screw snapped. I then had to remove the pipes and plate to drill out the broken screw. That worked and it all went back together! I managed all this with only removing the parts described in your page. So just to let others know even when it does not all go to plan you do not need to remove all the dash!"
Lonn Howard also used this method: "I changed my matrix o-rings by passing the socket extension through the glove box lock hole.... the extension was guided as if by magic to the cap screw almost every time. (The dealer) had never tried it that way, preferring instead to go through the space vacated by the radio. A word to the wise... refill with water only to test your connection."
Footnote: The official Land Rover dealers may now be cottoning on to this faster procedure pioneered by Thomas. The local dealer recently replaced my heater core O-rings (April 2003) and I was only charged for about 4 hours of labor.
Parts Required:
2 heater core O-rings, part number STC 3262.
Tools Used
Above: The tools required for the job. Note the flexible bit-driver.
Below: I replaced the phillips head screw with a socket head cap screw cut to the right length, hence the need for the allen key drive bit.
More Information
Dash Removal Method: Jos Geuze removed his dash (fascia), which is the O-ring access method recommended in the shop manual. He found this is not as difficult an operation as previously thought, and has provided a full illustrated description on the dash removal page.
Andy Cunningham has a text-only description of David Allcock's approach for the UK-spec 4.0/4.6, with alternatives by David Sparkes, at this link.
Return to Top
Return to Repair Operation Details
Return to Rangerovers.net Main Page
This page last updated 30th June 2005
Pascal
Pascaltissot is offline   Reply With Quote
Old 05-16-2006, 07:59 PM   #6 (permalink)
Sailcnc's Avatar
Default Left hand Drive Rover
Stopover: My rover is left hand drive. I started to do the 12 hr method. I gave up when it told me to remove the dash. I checked the net and found the shortcut. It is easy. I think you will have to go the whole nine yards to remove the matrix though.
Joe
