A rookie attempts to change transfer case chain - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 08-20-2008, 04:39 PM   #1 (permalink)
Default A rookie attempts to change transfer case chain
Help!
I own a 97 Range Rover p38. Recently it has developed a clunk clunk sound that occurs on acceration. At normal speed there is no sound. I have searched the help blogs and figure that it is the transfer case chain hitting the walls of the case. It has the Borg Warner transfer case on it. I have decided to have a go at the repair myself. I have jumped off the edge and ordered the hy-vo chain that is OEM replacement.
My question is: As a reasonably talented non-mechanic with all the tools to do the job, am I biting off more then I can chew? It appears to be a straight forward R & R on the transfer case, and then on into the case itself. I have been told that its not hard to find your way around the inside of the case and make the actual chain replacement. I am interested in hearing from anyone who has done this operation about the difficulty of the task, and where I might find any supportive blogs, diagrams, or other information.
Thanks in advance
skipbrakes!
skipbrakes is offline   Reply With Quote
Old 09-02-2008, 08:18 PM   #2 (permalink)
I took mine apart to replace the chain. I didn't quite replace it, but it was very easy to access, and I did pull it off to look at it. I found a replacement case, so my original is just sitting waiting for a chain. It was easy to open the case up.I did pay to have the old case removed and swapped with my new one. Taking it out of the car may be the most difficult part.
jrandsu is offline   Reply With Quote
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Changing out a transfer case on a 1995 Disco D1 texaninmass Discovery Series I 0 04-14-2008 06:12 AM
BW Transfer Case Clunk - Replace Chain? arcon12 Range Rover Classic 4 01-03-2008 12:55 PM
Diff Lock/Follow-up to transfer case removal helievacpilot Discovery Series II 2 03-28-2007 08:55 AM
Renewing fluids in differential, transfer case, swivel housings glenncof Range Rover Classic 2 03-05-2007 11:37 AM
Transfer case noise. BIRD Discovery Series II 5 01-25-2005 07:46 AM
SEO by vBSEO 3.3.2
