» Sponsors
» Sponsors
Old 09-12-2009, 03:41 PM   #1 (permalink)
Gallery: 1
Default Rough Idle on Range Rover 4.0S
I have a 1999 Range Rover 4.0S and I noticed that it is running rougher than normal. I don't really notice while driving. I did have the RPM's jump a little while at a stop light but stays at about 900 RPM while in drive (stopped). In park though, the RPM's are between 1500 and 2000. I did open the hood and make sure that all the plug wires are on good.
Let's just say it is running like it is dead winter and I am just starting it in the morning.
Any thoughts? Could bad plugs or wires do this?
cocalc is offline   Reply With Quote
Old 09-13-2009, 10:20 PM   #2 (permalink)
Gallery: 1
Bump....anyone here?
Old 09-22-2009, 01:15 PM   #3 (permalink)
nickm347's Avatar
If its running rough, and the plugs and wires are fine, try cleaning out the throttle body, MAF sensor, TPS sensor. These things could could a rough idle. Did your check engine light come on, or any faults at all?
nickm347 is offline   Reply With Quote
Old 10-25-2009, 03:30 AM   #4 (permalink)
you need to get fault codes read mate. could be any of the sensors nick mentions and/or knock sensors, lambda sensors, a jammed cat, poor ignition from coils......
'97 4.0SE, Manual, UK Spec.
Rasheed is offline   Reply With Quote
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 22 11-10-2009 06:47 PM
Rough 1996 Range Rover HSE Needs Work MN matz445 Land Rover Vehicles 2 06-06-2009 11:43 PM
Land Rover parts 20.000 items Range Rover Ltd Range Rover Classic 20 01-30-2009 02:37 PM
Rough Idle while in Gear? 95' RRC husaberg450 Range Rover Classic 4 03-11-2007 08:44 PM
British To The Core - The Land Rover Defender Serg General Land Rover Discussion 1 01-12-2006 11:57 PM
