Headliner is sagging from the rear forward to the point where the roof lowers to accomodate the sunroof! How can I fix this w/o spending big on a new headliner? y Classic had the same problem, I used clips which do work but I hate to destroy the roof so much on the 4.0. Has anyone tried ironing, regluing, etc?
Thanks in advance.
Current: 2005 Land Rover LR3 V8 SE w/ factory winch 1992 Land Rover Range Rover County Also current: 1995 Mercedes-Benz E320 Wagon 2002 Volkswagen Eurovan GLS 1996 Ford Explorer LTD 2WD 1982 Volvo 240 GL Diesel Previous Rovers: 2000 Land Rover Discovery II SD 1995 Range Rover 4.0SE |
I had a problem like yours. Since I knew i wasn't going to make it any worse i figured i would try a glue. I used gorilla glue, which is supposed to be very good and it worked out great. I did it about 6 weeks ago and even with the subs pounding in my truck it still stays. I would probably go with that. Just don't use too much, and put it on evenly. Hope this helps!
-andrew
98 4.6 HSE Customized to the season |
Thanks for replies, am I correct to assume you are removing the headliner from the vehicle, stripping the cloth off, and re-gluing?
| Thread Tools | |
| Display Modes | |
