GaryBaxter
Started my P38 this morning and got a Select Neutral message along with the annoying beep and flashing lights on the shifter console. Put it in neutral and no relief. Tried to engage Low gears and it seemed to work fine but still beeped and flashed. Engaged high gears and it drove fine but was still beeping and flashing. I did do some boondocking this weekend and used the low gears for a while. Any ideas?
THIS MAY HELP
AFFECTED RANGE: All vehicles with R380 manual gearboxes up to VIN WA 408338 PROBLEM: UNABLE TO SELECT Hi / Lo GEAR RANGE - NEUTRAL SWITCH SEIZED Unable to switch between Hi/Lo transfer gearbox ranges. When switch is pressed in an attempt to change transfer gear range, the instrument panel continually displays ‘SELECT NEUTRAL’. This occurs even though neutral is actually selected. CAUSE: Neutral indicator nylon cam jammed against indicator switch due to lack of lubrication. The nylon cam is positioned on the remote selector shaft within the extension housing. If this has been assembled without outer cam lubrication, the neutral indicator switch contact pin will jam against it resulting in damage to the cam and switch. When the switch jams, the ‘gear engaged’ signal is not detected so preventing transfer gearbox electronic selection. ACTION: On customer complaint of the above condition, the nylon cam and neutral switch will both require replacement. Refer to Workshop Manual repair number 37.16.29 for selector remote housing remove and refit. Use this repair information with the following cam replacement instruction: 1. Remove neutral switch from remote housing. 2. Remove nylon cam from remote selector shaft by levering cam off with a flat screw driver. It is likely that the cam locating pin will have broken off of the cam body and is still retained in its location in the selector shaft. If this is so, push broken pin remains from the shaft. |
