Old 01-21-2007, 09:08 PM   #16 (permalink)
mcnabj's Avatar
oh btw the paint is still drying in the pics.
mcnabj is offline   Reply With Quote
Old 01-21-2007, 09:49 PM   #17 (permalink)
Interesting. I would like to see pictures of it installed, when you get a chance.
skippy3k is offline   Reply With Quote
Old 01-22-2007, 07:25 AM   #18 (permalink)
mcnabj's Avatar
no problem. I think I might add a coat of some texture black paint.
Old 01-24-2007, 01:32 PM   #19 (permalink)
98RRover's Avatar
I like it. Probably was a lot easier than what I did too, haha.
98 4.6 HSE Customized to the season
98RRover is offline   Reply With Quote
Old 01-26-2007, 08:25 PM   #20 (permalink)
hermanpj's Avatar
Gallery: 4
dude that looks pretty sweet if you ask me. wont have to worry about it sagging any more either.
Pat Herman
Old 01-26-2007, 10:34 PM   #21 (permalink)
Life's Lemon
Life's Lemon's Avatar
That gives me fabulous ideas! nice work man!
1998 Range Rover P38
http://www.myspace.com/lifeslemon
Life's Lemon is offline   Reply With Quote
Old 01-27-2007, 10:28 AM   #22 (permalink)
mcnabj's Avatar
Thanks for the comments. Simple and sweat and cheap. just my style.
Old 02-15-2007, 08:40 AM   #23 (permalink)
Default results
Hi, can you send some picture on how things are going …I am thinking of doing the same on mine but first I want to see your results.
Thanks
Saludos cordiales,
Pascal
Pascal
Pascaltissot is offline   Reply With Quote
Old 02-15-2007, 11:31 PM   #24 (permalink)
Aftermarket security system installed
ikoinu's Avatar
Smile
This is probably the best info I have seen for replacing your headliner. Go to the address http://www.rangerovers.net/repairdetails/headliner.html and at the bottom of the page click on the "P38 Headliner Page" word document (download). Hopefully this is not too late for everybody.
ikoinu is offline   Reply With Quote
Old 02-18-2007, 03:49 PM   #25 (permalink)
98RRover's Avatar
the finished product looked great on the word document, unfortunately it probably won't last like that. With just glue the headliner will most likely start to sag again. Also, it looks easy to take it out, and he said it was, but that really isn't true. If you ask anyone who has done this they will tell you getting the headliner out and back in is no walk in the park. To hold my headliner up I have the glue that I used, along with very small pins that can't be seen.
Old 02-18-2007, 10:01 PM   #26 (permalink)
Otherwise known as STEVE
Headliners are time consuming... yuck. Why not just have it recovered by a pro? If you tell them it's already out, they'll quote you a cheap price- they hate pulling them too and you did the hard part. I had one covered for $89 show quality because I did the grunt work. Dynamat that roof while it is apart- it makes a HUGE difference.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 03-09-2007, 02:56 AM   #27 (permalink)
HeadlinerExpress
HeadlinerExpress's Avatar
Headliner Express in Central Florida does all the Headliner & Sunroof Repair for
Several Landrover Dealerships in Florida for the last 13 years. On the series models you need to make sure the 64 inch width material is used to completely cover the corners as well it needs to be the 1/8th inch thickness as original not the 1/4 inch in which other shops use which is to thick and not wide enough. For those looking to tackle the job their self’s here is a link for the correct material that needs to be used. www.HeadlinerExpress.Com
Headliner Express
Central Florida
68 Unimog TLF-8 Firetruck
65 Unimog Radio Box
www.HeadlinerExpress.com
www.LandroverHeadliner.com
HeadlinerExpress is offline   Reply With Quote
Old 06-21-2007, 10:00 AM   #28 (permalink)
Originally Posted by 98RRover
Note to everyone... DO NOT TRY TO DO THIS YOURSELF!!! haha. This was so much harder than I thought it was going to be. I starting putting the pieces back together tonight and should finish tomorrow. I'll take some pics once Im done.
Hi 98 RRover,
I’d like to retrim my door pillars. I did the A pillars (windscreen) with alcantara. Looks awesome.
I wanted to know how did you take the B and C out? Rave Manual isn’t very precise on this topic.
Cheers
Flo
996TURBO is offline   Reply With Quote
Old 07-20-2008, 06:55 AM   #29 (permalink)
HeadlinerExpress
Tools needed: 17mm wrench & socket
Remove Plastic Trim cover that hides the 17mm Nut on the "B" & "C" Post
Remove the Nut
Remove the Trim Molding and Recover
RE-Install
Let me know if i can help answer any other Questions. Bill
Headliner Express
Central Florida
65 Unimog Radio Box
