Hi everyone, I have a 2001 HSE Range Rover/LandRover. The front drive line went out the other day at 60mph leaving me, my wife and son stranded. I got it loaded on a trailer and sent to a local shop as there is no RR dealer/mechanic in our area. And after looking at the options I went with the mod drive line that has U joints not the factory rubber gasket. anyway they changed the drive line and all was going well till they took it off the rack and the truck is in Low range and will not come out. i mean I have tried everything.. short of taking the gear box apart. Is there a way to manualy put the transfer case into high? Thanks
got mud?
Did you try idling under 5 mph on a level surface, putting it neutral (still moving) then putting the truck in High gear? I believe that is what it says in the manual. goodluck.
DII -- Pete |
jimfoo
Or maybe try asking in the Range Rover section.
Jim Hall “That man has no respect for his Rover and beats the hell out of it every opportunity he gets, taking the most difficult line over each and every obstacle.” Michael 1966 88" 1.9l VW TDI, GT1749V, IC
Nut Futzer
first thing I noticed "HSE"
"Its a beautiful thing the destruction of words" “Don’t you see that the whole aim of Newspeak is to narrow the range of thought? In the end we shall make thought crime literally impossible, because there will be no words in which to express it.” - Orwell: nineteen eighty-four, true for Oceania, true for today. |
On my 97 HSE, I replaced the transfer case and it would not shift out of High gear. Turned out that the motor on the side of the case was bad. I took my old one and put it on, and everything worked again. Check the motor and also the electrical going to it.
| Thread Tools | |
| Display Modes | |
| Rear Hatch Door Stuck | Rookie | Discovery Series II | 6 | 06-26-2008 02:40 PM |
| If your key gets stuck in the ignition, do this | etischer | Tech & DIY | 2 | 08-06-2007 10:44 AM |
| Tape stuck in radio-Mode stuck on “tape” | Kris | Range Rover Classic | 2 | 01-28-2007 08:03 AM |
| '93 Range Rover emergency brake stuck | trellis8 | Range Rover Classic | 6 | 07-03-2006 08:57 AM |
| 88 ways to tell you're stuck in the 80's | apbtpetey | The Lounge | 35 | 01-20-2006 10:23 PM |
