Old 05-28-2008, 02:29 PM   #1 (permalink)
Default Stuck in Low need help!
Hi everyone, I have a 2001 HSE Range Rover/LandRover. The front drive line went out the other day at 60mph leaving me, my wife and son stranded. I got it loaded on a trailer and sent to a local shop as there is no RR dealer/mechanic in our area. And after looking at the options I went with the mod drive line that has U joints not the factory rubber gasket. anyway they changed the drive line and all was going well till they took it off the rack and the truck is in Low range and will not come out. i mean I have tried everything.. short of taking the gear box apart. Is there a way to manualy put the transfer case into high? Thanks
StuartHSE2001 is offline   Reply With Quote
Old 05-28-2008, 08:50 PM   #2 (permalink)
got mud?
Jupiter Rover's Avatar
Did you try idling under 5 mph on a level surface, putting it neutral (still moving) then putting the truck in High gear? I believe that is what it says in the manual. goodluck.
DII
-- Pete
285/75 r16 Destination M/Ts
Old 05-28-2008, 09:14 PM   #3 (permalink)
jimfoo
jimfoo's Avatar
Gallery: 9
Or maybe try asking in the Range Rover section.
Jim Hall
obstacle.” Michael
Old 05-28-2008, 09:36 PM   #4 (permalink)
got mud?
HA, I didn't even notice he had a RR.
DII
-- Pete
Old 05-29-2008, 12:52 AM   #5 (permalink)
zed
Nut Futzer
zed's Avatar
Gallery: 7
first thing I noticed "HSE"
"Its a beautiful thing the destruction of words"
“Don’t you see that the whole aim of Newspeak is to narrow the range of thought? In the end we shall make thought crime literally impossible, because there will be no words in which to express it.”
- Orwell: nineteen eighty-four, true for Oceania, true for today.
zed is offline   Reply With Quote
Old 05-29-2008, 12:42 PM   #6 (permalink)
XtremeMarine's Avatar
First thing I noticed was 2001. LOL!
Originally Posted by Elemental
Some guys play hard to get, I play hard to want.
Old 05-29-2008, 04:25 PM   #7 (permalink)
On my 97 HSE, I replaced the transfer case and it would not shift out of High gear. Turned out that the motor on the side of the case was bad. I took my old one and put it on, and everything worked again. Check the motor and also the electrical going to it.
jrandsu is offline   Reply With Quote
Rear Hatch Door Stuck Rookie Discovery Series II 6 06-26-2008 03:40 PM
If your key gets stuck in the ignition, do this etischer Tech & DIY 2 08-06-2007 11:44 AM
Tape stuck in radio-Mode stuck on “tape” Kris Range Rover Classic 2 01-28-2007 09:03 AM
'93 Range Rover emergency brake stuck trellis8 Range Rover Classic 6 07-03-2006 09:57 AM
88 ways to tell you're stuck in the 80's apbtpetey The Lounge 35 01-20-2006 11:23 PM
