Old 07-07-2008, 11:18 AM   #1 (permalink)
Default Sunroof Leak
I have a 2008 RRS. I noticed that water drops are coming from the sunroof every time it rains. If take it to a car wash, the water leak becomes more intensive. I have taken vehicle to two different dealers and they’ve told me that is absolutely normal for water to filer through the sunroof…I was wondering if everybody is experiencing the same issue…I just can’t conceive in my head for something like this to be normal…I have had many cars with a sunroofs and never I’ve had this type of problem before.
Thanks to all
jrhguez is offline   Reply With Quote
Old 10-07-2008, 04:48 PM   #2 (permalink)
I don't have a RRS but on the p38A, the sunroof drains get plugged with leaves and dirt and it leaks inside the cabin. You might want to look into that.
Zubi is offline   Reply With Quote
Old 10-07-2008, 05:20 PM   #3 (permalink)
I am sorry to hear about your difficulties, I hate it when things do not function right. Here is my thoughts-
You own a 2008 and you have leaks? Take it back to the dealer and complain to them that you should have no leaks period. You don't pay Land Rover Prices to deal with leaks off the lot!---
I have an older LR and yeah I have leaks...but it is older and understandable to me to have a few leaks. I will say that I have no leaks from the sunroofs though and mine is a 2001.
duckhunteryolo is offline   Reply With Quote
Old 10-08-2008, 06:46 PM   #4 (permalink)
RRS and lr3 have same design sunroof and leak in the same places.
Old 10-08-2008, 09:15 PM   #5 (permalink)
jorgelarach48's Avatar
I have the RRS 06 and also having the same problem with leaks in the sunroof, but it only spills when I take it to an automatic carwash. I think it's because of so many pressure that the carwash machine does, but still don't have to spill even a drop inside the car. I also complain with the dealer and they checked it but everything appears to be good.
jorgelarach48 is offline   Reply With Quote
Old 10-30-2008, 06:16 AM   #6 (permalink)
HeadlinerExpress
HeadlinerExpress's Avatar
The Dealership wont like this but the only way to properly diagnose the water issue is to remove the Whole Headliner Board and water test to see where the water is coming from.
When the Discovery's were in production they too had water issues from over head only to find out that most of those issues were not sunroof related but most had leaky front windshields.
The dealerships or repair shops can only assume or guess what might be causing the water issues unless they remove the headliner board and water test your problem, if you cant see it with your own eyes where the water is coming from how can you resolve the problem.
I agree a new 08 should not have issues with water coming into the cabin this soon!
Sunroof seals in general are really only designed for 3 reasons.
#1) Reduce the amount of water flow into the lower tub assemble
#2) Reduces the amount of wind noise
#3) Helps prevent large objects like,twigs,leafs,egg corns, Halloween gremlins from blocking your drain tubes and forcing water into your cabin.
All sunroofs leak, in reality it only take on granular of sand between your sunroof seal and the body of the car for water to come into the sunroof, also if you notice your sunroof seal is a combination of Rubber and cloth. If my memory is correct if you add water to cloth its like a sponge and attracts water.
Bottom line if your drain tubs are "not blocked" and draining properly then your water issues are coming from somewhere else. Request the Service Manager to Have the Headliner Board Removed and water tested.
They get paid either way.
Hope this helps, let me know if i can help in anyway.
Bill
Headliner Express
Headliner & Sunroof Repair
Central Florida
68 Unimog TLF-8 Firetruck
65 Unimog Radio Box
www.HeadlinerExpress.com
www.LandroverHeadliner.com
HeadlinerExpress is offline   Reply With Quote
Sunroof leak, not the tubes? R_Lefebvre Discovery Series II 5 10-22-2008 02:01 PM
Rear Sunroof Leak!! DiscoIPR Discovery Series I 5 09-19-2008 07:14 AM
From the makers of Spray on mud comes.... Elemental The Lounge 9 08-24-2007 12:24 PM
Sunroof leak rqwilliamsjr Range Rover Classic 8 11-21-2006 08:30 AM
Sunroof Leak totallymann Discovery Series I 1 05-21-2005 02:14 PM
