Timing belt replacement - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 9 (permalink) Old 10-15-2008, 06:10 PM Thread Starter
Quoted: 0 Post(s)
Hi. Is there a rule of thumb on when the timing belt is recommended to be replaced? I am looking at a 2000 Range Rover HSE with 94,000.
Thanks
Petron is offline
post #2 of 9 (permalink) Old 10-19-2008, 06:54 PM
Jagfixer's Avatar
Quoted: 12 Post(s)
Garage
Mine actually broke at 105,000 miles and bent a valve. Not a hard job for DIY, otherwise find and independent to do the job, if money is a concern.
Larry K, ASE
2011 LR4 HSE LUX
previous owns: 87 Classic
96 Disco, 96 P38
Jagfixer is offline
post #3 of 9 (permalink) Old 10-25-2008, 07:20 PM
Quoted: 0 Post(s)
Don't you mean timing chain
eurodmguy is offline
post #4 of 9 (permalink) Old 10-26-2008, 07:23 AM
Quoted: 0 Post(s)
Had to change oil pump at 110,000. It went out. Changed the timing chain at the same time. Easy. Good time to change water pump when you do your chain.
jrandsu is offline
post #5 of 9 (permalink) Old 10-26-2008, 07:24 AM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 35 Post(s)
Timing chain is the answer on that one. There really isn't a prescribed replacement interval on that part that I know of.
1972 MGB
Coming Soon 2006 LR3
Trident Green, 1983 110
Need new parts, genuine Land Rover, aftermarket and off road upgrades, Support the Vendor that supports the Land Rover Community and Forum
716-898-8153
Have a DII you need a drive shaft click here
Want a
best read this first
Need used parts?
ArmyRover is offline
post #6 of 9 (permalink) Old 10-28-2008, 04:18 PM
Former LR tech, Albany NY
Quoted: 0 Post(s)
those chains dont really break, its the other stuff that is needed for leaks.
I used to work on Rovers. Got a question just ask, need a Rover looked at, Albany, New York.
Rovin4life is offline
post #7 of 9 (permalink) Old 11-04-2008, 10:34 AM
Jagfixer's Avatar
Quoted: 12 Post(s)
Garage
I mentioned mine went at 105K. Actually chain broke straight across all 7 links. Seems that a dealer in US ( confirmed dealer services in owner's manual) replaced the waterpump and put a long bolt in wrong place ( for a short time ) and broke the inside reinforcement around bolt , probaly tried to start engine, then changed bolt after which the engine could turn over. After a while the broken aluminum bits wedged in the chain and broke three teeth on the crank gear which then messed the timing. After a while the chain continued to fall apart and scraped the inside of the timing cover, luckily not enough to go through before it fell apart and bent a valve. Some US techs must be under pressure to get done on time and not to watch the details on re-assembly. Never understood these time issues as I worked for a Jag shop and could get done under time and not forget a single bolt or washer. My Discovery has 112K and runs quite well. I did change the timing chain and gears in my 88 RRC for 110K maintenance and the chain was getting loose.
Larry K, ASE
2011 LR4 HSE LUX
96 Disco, 96 P38
Jagfixer is offline
post #8 of 9 (permalink) Old 09-10-2010, 01:10 AM
Quoted: 0 Post(s)
Why are replacing you timing belt kit? Did it broke or something? How many miles did already drove?
Brandon Mitchell is offline
post #9 of 9 (permalink) Old 09-10-2010, 06:40 AM
Site Sponsor
Quoted: 0 Post(s)
Typically timing chain lasts long. I dont think it is one of the preventative maintenance parts. If you need one:
Land Range Rover Discovery Defender Timing Chainr
bpUtah is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
timing belt question big_jarrs Freelander / LR2 8 05-03-2010 03:33 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 22 11-10-2009 04:47 PM
Cincinnati, anyone? Timing belt service question... Poinciana General Land Rover Discussion 1 07-27-2007 04:43 AM
Cam Belt or Timing Chain DEANJS Freelander / LR2 1 04-16-2006 03:49 PM
200TDi Timing belt DIY replacement Elips Defender 10 05-22-2005 10:00 AM
You may post new threads
You may post replies
