Old 07-26-2006, 10:26 AM   #1 (permalink)
Default Top Coolant Hose "Popped" Off?
While I was sitting in a drive-thru for about 10 minutes, I heard a "pop" and saw the steam rising. At first thought it was a torn hose, but when I looked, the top hose came off the radiator. The temp was dead center before, and after putting the hose back on and toppin goff the fluids, all seems well. What would cause this to happen? I just had my 90K, and the hose was fine and was not a recall hose. Could it have been an air bubble? I don't know, but hopefully someone will. Let me know what you think...
1997 Range Rover HSE 4.6
"It's not an oil leak, he's just marking his territory."
Ezrelda is offline   Reply With Quote
Old 07-26-2006, 10:41 AM   #2 (permalink)
RageRover's Avatar
How hot was it outside that day?
Might've been a big build up of pressure in the system that caused the hose to pop off, usually they would tear, I would think, never seen that happen before.
1995 RRC LWB
-RTE 2" Lift Springs
-KMC Front Diff Guard
-T-Case out of an 92' RRC
Old 07-26-2006, 11:59 AM   #3 (permalink)
The ambient temp must have been around 100F. It's Florida. I ran her in my driveway with no problems for half an hour and no problems and the temp outside is about the same. It does have the spring clamp tightener not the screw clamp type if that makes a difference.
Old 07-26-2006, 06:04 PM   #4 (permalink)
RageRover's Avatar
Yeah, if someone had serviced it before, typically you don't reuse these spring load clamps, they are usually meant for only one time use.
Has someone serviced that truck's cooling system?
1995 RRC LWB
Old 07-27-2006, 10:51 AM   #5 (permalink)
Have your cooling fans all been working, if not that could have caused the overheat. I would suggest you replace the spring clamp with a screw type and add coolant back. maqke sure you bleed all the air out of the engine or you will start running hot.
