Transmission fault? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 2 (permalink) Old 10-24-2008, 03:37 PM Thread Starter
ClassicRange's Avatar
Quoted: 0 Post(s)
Transmission fault?
Hi,
My recently bought 4.0 ltr. p38 1998 model has a weird problem and i was wondering if anyone had any clues. The problem is like this:
While cruising the highway the other day, the engine started to rev up and power was lost to the wheels. The transmission seemed to be slipping. I stopped the vehichle and it wouldnīt move at all. Neither in D nor R. Absolutely nothing happened when moving the shift lever between D and R, although the indicator in the dash displayed the correct position.
I had the car towed to a garage and inspected. No axle snaps or anything.. - dropped the pan on the transmission and the fluid was clean and no debris. All very clean.
Converter is turning, so the flex plate isnīt broken. Transfer case isnīt at fault, since the parking lock works and wheels are locked.
Car sometimes displays " gearbox fault " when I try putting it in D or R and rev the engine...
Dealer diagnostic tool canīt communicate with the transmission control module.
It is like that now, and Iīm out of ideas.
-Any help and ideas much appreciated.
Thanks,
S.Ben
ClassicRange is offline
post #2 of 2 (permalink) Old 01-03-2011, 04:58 AM
Quoted: 0 Post(s)
hi did you check the fuses under the drivers seat?
anger rover is offline
  Land Rover Forums : Land Rover and Range Rover Forum > Land Rover Model Forums > Range Rover P38, Mk III and Range Rover Sport
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 5 01-17-2015 07:46 PM
(S) Trans Sport mode light flashing Disco Xpedition Discovery Series II 15 04-17-2008 05:04 AM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 07:00 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 09:16 AM
transmission shift fault rikgarside Range Rover Classic 2 11-14-2004 11:31 AM
You may post new threads
You may post replies
