» Sponsors
» Sponsors
Old 06-02-2009, 11:31 AM   #1 (permalink)
Default Truck tilting/sagging on drivers side
cant seem to find anyone else with this symptom, any ideas?
99 Range Rover
Stevelkinevil is offline   Reply With Quote
Old 06-02-2009, 11:39 AM   #2 (permalink)
Do you still have the air suspension? If so, your bags are probably leaking. Also you'll want to check that your sway bar link has not broken. If you have the coil conversion, most likely either your coils on that side are worn out or the sway bar link is broken/unhooked.
rokrawlr is offline   Reply With Quote
Old 06-02-2009, 11:48 AM   #3 (permalink)
I do still have the EAS, i will check the sway bar link. I thought if it was a leak the EAS would just keep self leveling till the air ran out?
99 Range Rover
Old 06-02-2009, 02:43 PM   #4 (permalink)
RoverGuy82
I have a 1998 Range Rover that just started doing the same thing. The thing is sagging on the passenger side though. Even when the airbags are fully inflated, the thing sags. I'm taking the airbags out this weekend and having them switched to the other side to see if it is an airbag problem. I'm worried it might be a problem with the amount of air the computer is telling the compressor to send to the passenger side. It could also be the valves next the compressor that are giving out. We'll see. Let me know if you figure anything out. I'll do the same.
Roverguy82 is offline   Reply With Quote
Old 06-02-2009, 03:07 PM   #5 (permalink)
yea i am concerned about the same thing, i really like the air suspension and would like to keep it, just hope its not some major issue.
99 Range Rover
Old 07-01-2009, 04:28 PM   #6 (permalink)
Can we assume you've read the appropriate section in RAVE, and you're familiar with the workings of the EAS system?
That's step 1.
tilting/sagging is usually a result of an air leak.
Did you check that yet?
Generally, the OEM bags will start to develop some "cracks" at the foldover around 60K miles, depending on environment. They're kinda "fishmouth" looking things, and only open up right at the foldover; this means it'll leak at 1 height but not another.
Eventually, the rubber o-rings will harden and need replaced.
Rocking horse activity (the truck goes up and down on it's own, seemingly trying to find level) usually points at a dying or faulty driver module in the EAS system.
The airlines may have just worked loose and need reseated.
Get a windex spray bottle, dump out the windex, fill the bottle with water and some dish washing liquid (just a bit).
Liberally spray all the air lines and bags with your bubble juice.
If you see air bubbbles, you have a leak.
It takes longer to put the truck on jack stands than it does to swap an air spring.
Rebuilding the valve block takes an hour or 2, give it 4 hours start to finish if it's your first time.
1. Read RAVE.
2. Do bubble test.
3. Fix problem.
jim-00-4.6 is offline   Reply With Quote
Driver's Side Door Handle won't Open PDX Disco II Discovery Series II 0 02-23-2008 07:29 PM
1988 RRC and parts truck in NH/ME $2500 TOZROVR Land Rover Vehicles 2 01-28-2005 09:18 PM
knocking-tapping noise on drivers side of engine... ronrover Range Rover Classic 10 01-28-2005 12:42 AM
Rear drivers side quarter window OaklandRover General Land Rover Discussion 1 12-04-2004 12:22 PM
