Old 12-27-2007, 11:40 PM   #1 (permalink)
max
Default uncommon EAS fault, doesn't go down, but up by itself
hi
i have a hard time getting my RR into the crawl mode
it takes serveral minutes to go down - last couple of weeks it won't lower at all
Instead it started going UP by itself!
locking in on highway mode helped for a while, but shortly she doesn't care about my comands ;-)
There are no Errors in the ECU
i had the dryer changed - still no luck
I have no error message in the display - only the top lamp within the driver control switch is blinking.
Depending on what level is chosen, the corresponding lamp is also blinking.
Like telling: wanted level is not reached - sometimes going into high profile
any advise is welcome
thanks
max - germany - 4.6 HSE MY2001
max is offline   Reply With Quote
Old 01-08-2008, 12:46 AM   #2 (permalink)
hi
thanks
Hi max,
This issue is often due to a bad height sensor.
Have it checked with T4 or multimeter
Cheers
Flo
996TURBO is offline   Reply With Quote
Old 01-10-2008, 12:41 PM   #3 (permalink)
max
Default prob solved
diaphragm valve in the pits
rep kit part no stc1803 (aprox 70,-- EUR)
1/2 hour work + eas calibration
works like new
thanks
max
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 07:00 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 09:16 AM
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 1 12-19-2006 06:43 PM
Gearbox fault warning message SPS Range Rover P38, Mk III and Range Rover Sport 1 01-09-2006 01:25 AM
P1178 Maximum Positive AMFR Correction Fault Serg Discovery Series I 2 05-01-2005 08:31 PM
