When considering extended warranty on a 2002, what coverages are most important?
I am deciding between purchasing two different 2002's, both with similar mileage, 66-69k.
The warranty I am looking has the following coverages. Is it excluding any major component (airbags, ac?) that I should be concerned with, or does this look like solid coverages?
Thanks in advance.
Engine: All internally lubricated contained within the engine block, cylinder head(s) or rotary engine housing(s); oil pump; timing belt or chain, timing gears and timing tensioners; water pump. Engine block, cylinder head(s), cylinder barrels. Harmonic balancer, flywheel; intake and exhaust manifolds; engine mounts; valve covers; oil pan, seals and gaskets. Timing belt or chain cover, dipstick and dipstick tube.
Automatic/Standard Transmission And Transfer Case: All internally lubricated parts contained within the transmission case, torque converter case or transfer case. Transmission case, torque converter case, transfer case and external cover(s) and pan(s) if damaged by the failure of an internally lubricated part. Transmission mount(s), vacuum modulator, filler tube and dipstick; flex plate; internal electronic control unit; overdrive unit; seals and gaskets. Coverage is not afforded it for Standard Transmission Clutch assemblies, or any of their component parts.
Front And Rear Drive Axle: All internally lubricated parts contained within the drive axle housings. Drive axle housing if damaged by the failure of an internally lubricated part. Drive shaft(s); hub assembly and bearing(s); constant velocity joints; universal joints; seals and gaskets.
Turbocharger/Supercharger: Turbocharger/Supercharger housings and all internal parts; waste date; intercooler. Seals and gaskets.
Front And Rear Suspension: Upper and Lower control arms, shafts and bearings or bushings; upper and lower ball joints; king pins and bushings; spindle and spindle support; MacPherson struts; torsion bars and bushings; wheel bearings; leaf springs, shackles and bushings; coil springs; stabilizer bar, linkage and bushings; Compressor; seals and gaskets.
Brakes: Master cylinder; vacuum assist booster; hydraulic lines and fittings; wheel cylinders; calipers; Pressure-Differential, metering, proportional and combination valves; brake pedal assembly; parking it brake lever.
Steering: Power steering pump; Steering box; racket and pinion. Steering shaft and couplings; idler arm; tie rods, tie rod ends; pitman arm; center and drag link; cooler and cooler lines, Pressure Control valve; seals and gaskets. Centering lock spring and phase control, tilt/telescoping steering assembly, Steering dampener; four-wheel Steering output shaft/rod, variable assist power steering computer.
Air-Conditioning: Compressor; condenser; Compressor Clutch, field coil and Clutch pulley; idler pulley and bearing; evaporator; blower motor and fan; receiver-dryer/accumulator; air ducts; expansion valve/orifice tube; suction throttling/POA valve and tube; air-conditioning control panel and control module; seals and gaskets.
Fuel: Mechanical and electrical fuel pumps; diesel vacuum assist booster pump. Fuel injector pump; fuel distributor; fuel lines and fittings; fuel pressure regulator; fuel injectors; fuel tank; fuel injection sensors and air flow sensors; electronic fuel ignition computer control module; seals and gaskets .
Electrical: Alternator; voltage regulator; starter motor; starter motor solenoid. Front and rear window wiper motor; windshield wiper delay module; washer pumps, power antenna motor; distributor; dash and engine main wiring harness; spark control sensor; electronic ignition module; turn signal switch; horn switch and horns; rear window defogger; power trunk motor, trunk release switch and trunk release solenoid, headlamp switch, electronic level control module; height sensor; electronic (L.E.D.) driver display and control module; front and rear washer pumps; retractable headlamp motors and manually operated switches for the above listed components.
Cooling: Radiator, radiator brackets; fan, fan clutch; electric fan motor; fan that relay; fan shroud; idler pulley/belt tensioner and bearing; coolant recovery tank.
Interior And Exterior: Hood/trunk/hatch hinges, latches, gas cylinders and springs; door handles and hinges; seat tracks; glove box light; ash tray assembly; shift lever.
Safety Coverage: ABS brake systems and electronics, Hydraulic control unit; all safety airbags and sensors; seat belt fasteners, seat belt/restraint system motor and servo; retractable child seats; door locks; child safe door locks; Automatic and central door locking systems, window disabling system; traction control systems; electronic modulated suspension; Bumper Absorbers; Automatic roll bar system and manually operated switches for all of the parts listed under " safety coverage ".
Security Coverage: Illuminated keyless entry; remote and electronic entrance device; Factory Installed anti-theft devices; not whites and compartment lighting; Factory Installed Ignition of fault device; all manually operated switches for the parts listed under "Security Coverage".
Convenience Coverage: Speed/Cruise Control module and servo; temperature control programmer; convertible top motor; sunroof motor; power seat computer; computer-circuit boards and dash gauges; computer dash module; power window motors; power mirror motor; rear compartment air-conditioning control panel; Automatic day/night mirrors; heated seats; illuminated visor vanity; trip odometer; engine block heater; thermometer, manually operated switches for all the parts listed under "Convenience Coverage" .
