» Sponsors
» Sponsors
Old 09-18-2009, 07:28 AM   #1 (permalink)
Default Where is the EGR valve on 2001 4.6?
I have a 2001 Range Rover HSE 4.6 with the code 1412 which says the EGR valve is frozen. Where is the EGR valve and can it be unplugged or bypassed on the 4.6? Will the EGR valve cause a miss in the number 5 cylinder on this model? I know it will on american vehicles but not sure about a Rover. I got the message on the reader random misfire in cylinder 5.
I also have the code 1415 which is the air pump circuit. Will the air pump cicuit cause my Rover to have a miss in the engine?
Any help at all will be greatly appreciated.
Larry038 is offline   Reply With Quote
Old 09-18-2009, 08:52 AM   #2 (permalink)
TerryS's Avatar
You might try reposting your question in the appropriate section for your model.
Possible sticking exhaust valve pavel Discovery Series I 5 07-13-2009 07:56 PM
Idle Control Valve - idle problems; get to know it glenncof Range Rover Classic 2 02-24-2008 01:57 PM
smoke test negative drum655 Discovery Series II 10 11-07-2006 09:28 PM
obd2 code 96whitelandy Discovery Series I 2 05-02-2006 11:06 PM
Location of Fuel Rail / Schraeder Valve adrianb Discovery Series II 0 08-30-2005 10:35 PM
