Old 10-07-2007, 10:11 PM   #1 (permalink)
hermanpj's Avatar
Gallery: 4
Default window not set plus bad noise
Window lift suddenly made a bad, loud, rattling/ratcheting noise and the door literally seemed to shake. "LH Window Not Set" is proudly displaying in the message center. Son of a b$tch.
Does this mean I need a new regulator or is it possibly some relatively cheap and easy problem to fix like a maybe a gear with stripped teeth?
THanks for any wisdom.
Pat Herman
Old 10-09-2007, 01:23 PM   #2 (permalink)
New reg - unless you are very handy with welding and filing.
buick215 is offline   Reply With Quote
Old 10-11-2007, 09:18 AM   #3 (permalink)
hermanpj's Avatar
Gallery: 4
did this same problem happen to you?
Pat Herman
Old 10-11-2007, 01:14 PM   #4 (permalink)
Many times - I own a LR repair shop,we just replace the reg as its not worth the hassle if the repair fails.
Old 10-13-2007, 10:35 AM   #5 (permalink)
hermanpj's Avatar
Gallery: 4
thanks man. right now the window is going up and down well - it just makes that terrible noise. so i guess i should replace the regulator before it really breaks and leaves me in a bad way. thanks for the advice.
Pat Herman
Old 10-13-2007, 03:50 PM   #6 (permalink)
Unfortunately this is a very common issue. Classics don't seem to have this issue nearly as often.
1987 Range Rover
1989 Range Rover
1995 Range Rover County LWB
1998 Range Rover 4.6HSE
TNRRClassic is offline   Reply With Quote
Old 10-13-2007, 07:34 PM   #7 (permalink)
hermanpj's Avatar
Gallery: 4
anyone know cheap source for a new window regulator
Pat Herman
Old 10-17-2007, 02:18 PM   #8 (permalink)
I got a reg of ebay for 30.00 pounds brand new, also got the mechanism for 25.00 pounds.
RR99DSE
RR99DSE is offline   Reply With Quote
Old 10-21-2007, 09:08 PM   #9 (permalink)
hermanpj's Avatar
Gallery: 4
THANK YOU!
Pat Herman
Old 10-30-2007, 09:29 PM   #10 (permalink)
Series Moderator
onslow's Avatar
Git exactly the same problem with my 97 p38 bloody thing
Current fleet
86 90 V8 in bits
86 RR classic Under repair
94 Disco TDI 3dr ex-police 256k and still going
80" coil sprung V8 auto Trialer in progress
71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine
Stuff I have had at one time or another
76 S3 LWB
65 2a ex mil swb
71 2a swb safari
67 2a 1 tonne TACR
57 S1 V8 SWB
81 S3 SWB diesel
82 s3 SWB diesel
82 RR 2 dr perkins diesel
83 RR 4dr V8
84 RR 4dr V8 LPG
83 RR 4dr V8 LPG "in vogue"
88 RR gm 6.2 V8 Diesel
89 RR 3.5 mazda TDi
75 S3 LWB stationwagon
75 S3 2.6 LWB
86 110 2.5D
91 disco V8
91 disco TDi
89 disco V8
81 RR isuzu 2.8 TD
Old 11-01-2007, 01:53 PM   #11 (permalink)
hermanpj's Avatar
Gallery: 4
have just been ignoring mine. window still goes up and down... for now. my 1991 is in about 250 pieces while i redo it and i just dont have the patience to F with my 4.6 today. :-)
Pat Herman
