» Sponsors
» Sponsors
Old 10-29-2009, 04:33 PM   #1 (permalink)
mtnance's Avatar
Default 03 Oil Pump Pins
I can't find where, but I thought I read that these pins causing a misaligned pump can be removed and the cover reinstalled, assisting in a proper alignment? Did I read this right? Is it truly a possible thing to do?
Plus: Have to replace heater blower, making a vibration, is there anything to watch out for?
2000 DII (sold)
2003 D (stock)
1977 MGB (runs!)
mtnance is offline   Reply With Quote
Old 10-30-2009, 12:16 PM   #2 (permalink)
Default Timing cover pins
Look at the posts on oil pump/ pressure problem, there is an interesting article about this issue.
bonnettoboot is offline   Reply With Quote
Old 11-01-2009, 03:18 PM   #3 (permalink)
03discoveryrover's Avatar
you can pull the pins i've done it
03discoveryrover is offline   Reply With Quote
Old 11-02-2009, 04:46 AM   #4 (permalink)
Toowild78's Avatar
How hard was it to remove them?
Also did you see any signs of damage?
Toowild78 is offline   Reply With Quote
Old 11-02-2009, 01:21 PM   #5 (permalink)
Default Oil pump issues
The point is, it may not be a pin problem. You need to read the earlier comprehensive post on Oil pump pressure problems.
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 22 11-10-2009 06:47 PM
Finally blew the power steering pump. DiscoDream2 Discovery Series II 14 11-01-2009 09:17 AM
RRC oil pump rebuild roverthen Range Rover Classic 1 05-14-2008 08:57 PM
My SLS pump, let me show you it. V. Pics Grid_Lock Discovery Series II 2 03-30-2008 06:16 AM
HELP!! Fuel Pump??? Truck still on trail. bluemax09 Discovery Series I 14 02-22-2006 04:40 PM
