i am not sure how a set of springs will effect the camber on a solid axle with no adjustments...
i would lean more to a bent axle casing...
you may also want to check all of the bushings as well if some are worn weird things may happen...lol
03 Land rover disco 2 -- ARB bullbar w/warn m8000, Custom rear bumper, 04 CDL installed, Muffler removed, 16" Steel rims 235/85 Destination MT's, Spare tire moved to load space, Pioneer radio, OME 2inch HD lift, Front and rear TruTrack diffs, scangauge2.
12 Mercedes-benz ML350 BlueTec 28-mpg
12 VW Touareg TDI Executive 30-mpg
