If you buy steelie wheels with the correct off set, 245's won't rub.
You might rethink staying with your warn suspension which has dropped an easy 1.5" from when it was new and install a small lift, if for no other reason then to get a much better rides both on and off the road.
I have an S which has the coils...I dont think it has dropped much. I am still in high school and have a limited budget. How much would i be looking at for the lift?
I hear you on your budget, I am on Social Security and trying to keep mine up also.
Trust me when I say your suspension is warn out and has dropped, and that is OK till you budget improves, but at some point you need to look at the coils and shocks for replacements.
Let us know how your truck turns out.
So Mike you are saying that new stock (or OME) springs and Shocks will lift my 99 DII about 1.5 inches? I am thinking about keeping same stock wheels and getting a Set of BF Goodrich AT T/A Ko's closest fit to stock size tires These will only be about 1/2 inch taller. I don't have sizes in front of me right now, but will replacing springs and shocks make the stock tires look too small? I want some off road capability, but I'm leaning toward a better ride since I like to travel in this one.
I have read many posts on this subject but I just seem to get more confused.
I am planning Shocks springs tires and brake lines soon so I don't want to buy tires that will look crappy.
Thanks
I Drive For Fun
99 Disco II 208000 and going strong
2011 Benz C class
Trek 720 Cross Terrain Bicycle
I like 245's with a short lift, everything fits/looks well together.
Once in a whiles one shows up, if you are patient.
If you want, send me your number and we can talk over the weekend.
I'd go with the 16" wheels. It might cost just a little more now for 16" wheels + tires, than for just 18" tires, but in the long run it will be cheaper and you'll have a broader selection of tires to choose from.
Also, if you're off-roading the 16" wheel gives you more rubber between the wheel and rocks, assuming same tire OD.
If you need new tires I'd go that route, rather than worrying about springs and shocks, unless they are in really bad shape. Especially if you're on a budget.
You can tell how much they've sagged by measuring. Your owners manual has the overall stock height listed (1900mm excluding roof bars) . Compare that to what it is now.
You do want to check the condition of your shocks though, because if they are worn badly they can cause premature tire wear which sucks with new tires.
Tom Rowe
Atlanta, GA
Definitely going 16 inch wheels good Idea about the measurement I never think of the easy way to do things. Makes sense. If I lifted My disco II a couple of inches I think I would need an extension for my D1 CDL shifter? (Should of went cable) a and longer brake lines. I can decide after measurement.
Also I have 220,000 miles on my Shocks it's probably about time
Thanks for your help
I Drive For Fun
2011 Benz C class
If you're doing a suspension lift it won't affect your CDL shifter. A suspension lift raises the chassis (which the Engine, gearboxes and body are bolted to, in relation to the axles.
When I put a 2" body lift (which does raise just the body) on my D1 I didn't need to extend the CDL shifter.
Tom Rowe
Atlanta, GA
I measured the height of my Disco last night. It's 1.5 inches lower than spec. Finding this out , I believe springs and shocks would help. It rides rough and a bit of shimmy in the steering when going 55 or above when I hit a bump so stabilizer is probably going to be needed also. I,m sure new tires will help this some.
Let the fun begin
I Drive For Fun
2011 Benz C class
Would 16" OEM wheels provide the proper offset for 245/75/16? I just bought my first Disco and it needs new tires. I'm trying to figure out a way to replace the wheels and tires now and have an "upgrade path" for a short lift later.
