Old 04-07-2006, 10:04 AM   #1 (permalink)
OkieRover's Avatar
Gallery: 2
Default 18 inch wheels
Do I want to stay on these wheels?
Or should I move to something a "normal" tire will fit on?
The 18's look good but is anyone offroading with them?
I don't invision myself rock climbing in my D2 but I would like to get off the pavement in the future.
I punch my clown daily.
Old 04-07-2006, 10:27 AM   #2 (permalink)
16'ers are a better way to go, the are less expensive and you get a much larger selection of tire sizes and treads. The side walls are strong and you will get a better ride cause you have more sidewall to cushion the ride.
Old 04-07-2006, 10:40 AM   #3 (permalink)
OkieRover's Avatar
Gallery: 2
Is the bolt pattern the same for all Land Rovers?
I.E. will Classic wheels fit on a Disco 2?
Old 04-07-2006, 01:03 PM   #4 (permalink)
Choqiees's Avatar
Im still using my my 18"
will change to 16" for more options
2002 Discovery II SE
1999 Range Rover P38 HSE
Old 04-07-2006, 01:13 PM   #5 (permalink)
There are 2 different bolt patterns for Rovers, those found on Defenders and older Rangies and D1's and the newer patter found on P38's and DII's.
Old 04-10-2006, 08:59 AM   #6 (permalink)
OkieRover's Avatar
Gallery: 2
I looked on expedition exchange for wheels with no luck.
Where does a fellow get a set of defender wheels for his Disco 2?
Maybe I should also say "in the United States?"
Old 04-10-2006, 09:03 AM   #7 (permalink)
You can't run Defender wheels on a DII.
Lots of used wheels on E-Bay and many of the Rover forums. Remember you can only use wheels from a P38 or new and DIIs.
Old 04-10-2006, 09:04 AM   #8 (permalink)
OkieRover's Avatar
Gallery: 2
Thanks Mike.
Old 04-10-2006, 10:31 AM   #9 (permalink)
smileyq's Avatar
You can get some black steelies at Safari gaurd for around $75 bucks a wheel or shop on here and somebody usually has some for sell.
"Good saddles ain't cheap, and cheap saddles ain't good."
smileyq is offline   Reply With Quote
