» Sponsors
» Sponsors
Old 11-03-2009, 08:28 PM   #1 (permalink)
Default 1999 Disco II transmission/front drive shaft problems
I recently purchased the Disco II and the previous owner advised that the transmission and front drive shaft will need to be repalced. This will be my first vehicle and need to know the following...fyi it has @ 89K miles.
[1] Do you think the shaft broke first and cracked the transmission or the other way around or does it really matter.
[2] Should I be concerned about the transfer case...it is not cracked from the visual inspection.
[3] any other issues that I will need to consider?
hotrodrigo is offline   Reply With Quote
Old 11-03-2009, 08:32 PM   #2 (permalink)
Super Moderator
rmuller's Avatar
driveshaft broke and took transmission out with it. Search around here for driveshaft replacement info... it's very very common on the d2s... the 'sealed for life' ujoints give way and the driveshafts go out.
Transfercase should be ok.
Call Paul Grant or Will Tillery for a replacement used transmission to save tons of money!
2001 Discovery II | 2006 LR3 HSE7 | 1994 Defender 90 #416 (Gone)
Old 11-04-2009, 07:45 AM   #3 (permalink)
Super Moderator
As mentioned, the drive shaft is the problem. Considering ordering a new one from Tom Woods on line.
As for the tranny, how mechanical are you and what area do you live in?
Old 11-04-2009, 10:53 AM   #4 (permalink)
I think I may have found someone who will do the transmission labor end of it for $150 - $200 and I am not that mechanically inclined...I probably could take the shaft...live in the Toledo, Ohio area....
Old 11-04-2009, 10:48 PM   #5 (permalink)
ok, so I started to read and watch the MBL game tonight and I became confused while I read the steps to change the transmission - LRT-99-008A - some type of brace to secure the engine [??]. My question - do I need to purchase this item or can I or the person who will help me bypass and use some other type of brace? Also, I assume I should follow all the instruction to change filters etc...I probably sound silly but I have never changed out a transmission before but the instructions are pretty detailed and I hope we will not have any problems.....
Old 11-05-2009, 07:02 AM   #6 (permalink)
Super Moderator
rmuller's Avatar
you can use a floor jack to secure the engine.
Old 11-05-2009, 08:00 AM   #7 (permalink)
Beta testing www.discogirl4x4.com
DiscoDream2's Avatar
Man, if you can get it installed for $150 jump on it! That is not so DIY..and certainly worth watching it happen with a beer in one hand.
1999 DII ~ ALPINE Edition
@>---^--- Discogirl4x4.com IS READY - COME VISIT! - Beta Version
Project DII:
New bumper cover w/trim, 2" lift, Bottorf Sliders, marker light, custom hood blackout, install DI CDL linkage, TW propshaft, diff guard-rear, mud plugs, Hi-Lift.
Completed
Head gaskets, synthetic oil, MAFS, coil pack, wires, alternator, tensioner pully, serp belt, PAS, fuel pump, 02/16" rims, 285/75/16 BFG KO, OE brush guard, wilderness roof rack, safari tail light guards, OE ladder, NATO fuel can, stereo upgrade, way cool oil gauge, Hella lights x6, CB radio, two rear trail/work lights.
DiscoDream2 is offline   Reply With Quote
Old 11-05-2009, 08:23 AM   #8 (permalink)
Default transmission/shaft - hotrodrigo
I think i will pay it and have it done by somebody else...right on.....
1999 Land Rover Disco II CodyNC Land Rover Vehicles 10 06-24-2009 04:23 PM
Looking to buy a 99 Disco 2 with the following problems: JaguarS4R Discovery Series II 6 01-26-2009 04:39 PM
Front drive shaft check? drum655 Discovery Series II 12 05-02-2006 06:23 AM
New Double/Double Cardon front drive shaft 92RRRANDALL Land Rover Parts and Accessories 1 02-11-2005 01:40 PM
99 Disco Front drive shaft failure Norwestdisco Discovery Series I 2 09-06-2004 10:30 PM
