Old 05-22-2005, 02:01 PM   #1 (permalink)
Default 2001 Disco II Rear-Seat Cupholders
Does anyone have installation instructions or a diagram for the rear-seat, pop-out cupholder assembly? The spring loaded assembly was kid tested and failed. It now requires reassembly. Thanks.
ezatrine is offline   Reply With Quote
Old 05-27-2005, 02:13 PM   #2 (permalink)
Default Follow Up to Rear Cup Holders
Problem Solved. The entire assembly must be removed from the arm rest to correctly reinstall the spring mechanism and deployable cup holder assembly. To remove there were two clips on each side that need to be depressed in order to pull the entire assembly out.
Old 05-27-2005, 02:16 PM   #3 (permalink)
Wheeler
SCSL's Avatar
Yep, that's a Land Rover alright,,,,,
Kinda like replacing a solenoid on the t-case,,, replacing/reversing the rear tire carrier,,,
etc
Old 05-27-2005, 08:41 PM   #4 (permalink)
is there a way to make sure the same problem won't happen again? Mine is broken right now, but i'm not sure it's worth it to fix it.
99 disco ii w/ cold climate and SLS.
plastic is offline   Reply With Quote
