2002 DII overheating... - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-20-2012, 12:54 PM   #1 (permalink)
Default 2002 DII overheating...
2002 DII with 170k overheats and gets exhaust gasses in the cooling system. Is this an issue with the head gaskets?
Thanks.
Nay-Sayer is offline   Reply With Quote
Old 11-20-2012, 01:18 PM   #2 (permalink)
Administrator
Sure is. By your question, I would say you are not very mechanical, do you have a shop you trust? Get a couple of estimates before you have the work started so we can make sure you are not getting screwed.
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 11-20-2012, 02:07 PM   #3 (permalink)
It's not my truck, there is a 2002 DII for sale locally and the owner says it over heats and has exhaust gasses in the cooling system.
What is a 170k 2002 DII with the head gasket problem worth in your opinion if everything else on the truck is in good order?
Thanks again.
Old 11-24-2012, 05:48 PM   #4 (permalink)
STAY AWAY!!!!! The D2 motor is very sensitive to block cracks when it over heats! You could land up doing the heads and still have the same issue
optiontrader00 is offline   Reply With Quote
Old 11-24-2012, 09:10 PM   #5 (permalink)
mbruneaux's Avatar
Try to get it dirt cheap because you have to assume it needs and engine.
Canterbury, CT
2000 Discovery II (Parts Truck)
2002 Discovery II SE7
mbruneaux is offline   Reply With Quote
Old 11-24-2012, 09:12 PM   #6 (permalink)
mbruneaux's Avatar
Thanks.
Where are you located? Maybe someone on here can direct you to a good shop that can look into it for you and like Mike said give you a worst case scenario estimate.
Canterbury, CT
Old 11-24-2012, 09:51 PM   #7 (permalink)
roverandom's Avatar
Not much, realistically it's worth more broken for parts so for a fixer upper I would try to stay well under $1000. Ideally $500-600. The vendor won't like the sound of that but let him sweat it for a few weeks and he may come around.....or not. Either way don't pay any more, there are plenty to choose from.
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
Matt.
roverandom is offline   Reply With Quote
New Owner 2002 DII goducks96 Discovery Series II 5 01-26-2011 11:17 AM
cleaning injectors DII 2002 katch Discovery Series II 4 10-10-2010 06:57 AM
DI transfer case into a 2002 DII? Black Magic Discovery Series II 2 07-30-2010 03:21 PM
Mysterious Overheating in 2000 DII troverman Discovery Series II 41 09-08-2009 09:20 PM
will these fit a DII 2002? 2002DiscoII Wheels and Tires 5 03-06-2006 07:49 PM
SEO by vBSEO 3.3.2
