2003 disco dash warning B with a line through it - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 23 (permalink) Old 10-18-2010, 03:31 AM Thread Starter
Quoted: 1 Post(s)
Unhappy 2003 disco dash warning B with a line through it
New member here, I looked everywhere for someone with similar issue cant find. Any help would be greatly appreciated. 2003 Disco 72k miles. Wife went to unlock doors, key fob not working, had to open manually with key. She starts car, starts to drive, sees B with line through it on the dash where the miles/trip odometer display. She gets to end of street and notices no turn signals as well. Now car will sometimes stick in a gear, so has to be turned off, then re-started to select gear. Car was fine the day before, any thoughts? Thanks in advance.
mole2002 is offline
post #2 of 23 (permalink) Old 10-18-2010, 04:48 AM
Administrator
Quoted: 5 Post(s)
Be more specific about the B with the line thru it. As far as I know we have no such warning light.
How old is your battery. If old, I would suggest you go to a local parts store and have them check you battery/alternator to see if you have a low voltage issue below 13.6 volts.
If that is not it, I hope you have a good Rover mechanic, not a dealer if possible.
Let us know what you find.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #3 of 23 (permalink) Old 10-18-2010, 08:55 AM Thread Starter
Quoted: 1 Post(s)
Photo of dash warning light attached
I have included a photo of the dash showing the B with a slash through it. Will check battery today and get back to you.
mole2002 is offline
post #4 of 23 (permalink) Old 10-18-2010, 10:25 AM
Administrator
Quoted: 5 Post(s)
Do you have your owners manual, if so I would read up on that indicator before you go driving much. my 99 D2 does not show that and you are the first to mention it.
Need Parts?
Lucky8,
post #5 of 23 (permalink) Old 10-18-2010, 10:34 AM Thread Starter
Quoted: 1 Post(s)
I read the manual front to back when it first happened, nothing listed in the manual. Called 2 dealers, they only suggested bringing it in for $115 diagnostic check. Just went to my friends (small used car dealer) his mech checked battery 13.8 volts. Got fault codes P1412, P1415, and P1173.
mole2002 is offline
post #6 of 23 (permalink) Old 10-18-2010, 11:26 AM
Administrator
Quoted: 5 Post(s)
The 2 1400 codes are Secondary Air Injection fault codes, the 1173 is a lean code, I believe.
Time to go see a good Rover shop, not the dealer.
Need Parts?
Lucky8,
post #7 of 23 (permalink) Old 10-18-2010, 11:53 AM
member
SafariDave's Avatar
Quoted: 20 Post(s)
it could be the xyz
Dave
The City is a Jungle.
2005 LR3/ SE 4.4 Fancy Professor (my girl's LR3)
2005 LR3/Disco3 SE 4.4 The Rhino
(mine)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255 55 19"
1999 LR Disco II SD 200,900 miles (Sold)
1991 Range Rover Classic (Sold) 'The Turtle'
1988 Range Rover Classic (Sold) 'The Rust Bucket'
SafariDave is offline
post #8 of 23 (permalink) Old 10-18-2010, 02:08 PM Thread Starter
Quoted: 1 Post(s)
thanks for your help Mike. Does anyone know a good independent LR mechanic in the West Chester PA area?
mole2002 is offline
post #9 of 23 (permalink) Old 10-19-2010, 05:33 AM
discoGraham's Avatar
Quoted: 0 Post(s)
crazy B indicater.
That is just the indicator that shows if the transmission is in park(P) or reverse(R) and so on. It appears that all of the letters are lit up at the same time on yours.
Graham
Holly Springs, NC
'04 Discovery se7
discoGraham is offline
post #10 of 23 (permalink) Old 10-19-2010, 06:14 AM
DiscoDream2's Avatar
Quoted: 1 Post(s)
Nice call. I haven't seen that one before...
DiscoDream2 is offline
post #11 of 23 (permalink) Old 10-19-2010, 06:44 AM
Administrator
Quoted: 5 Post(s)
Originally Posted by SafariDave View Post
it could be the xyz
Dave
David, you might be right. I was just thinking about the B and not the other gear positions that would normally show up in that area, so the tranny switch could be the culprit.
Need Parts?
Lucky8,
post #12 of 23 (permalink) Old 10-20-2010, 07:05 AM Thread Starter
Quoted: 1 Post(s)
Had to take it to the dealer. Turns out their is a short in the fuse box. They said they need to rerplace the IDM? cost with labor $780. (that takes care of the goofy flashing B in the dash warning light, and the loss of signals and power windows) They also said I need a new SAI pump and (2) 02 sensors. $630 for the SAI and $569 respectively. Total cost to repair if I decide to do it $1979. Ugh!
mole2002 is offline
post #13 of 23 (permalink) Old 10-20-2010, 09:01 AM
beamacvt's Avatar
Quoted: 0 Post(s)
SAI is not difficult to do on your own... replaced mine with one from Ebay for around $100.00 shipped.
O2 sensors are not difficult either... you can get them from Atlantic British I think for around $70 per sensor depending on whether they are front or rear.
Can't help you with the fuse box shorting out, but you may want a second opinion from a good mechanic with rover experience.
95 DI
beamacvt is offline
post #14 of 23 (permalink) Old 10-20-2010, 09:08 AM Thread Starter
Quoted: 1 Post(s)
beamacvt- thanks much for your response. Maybe I will do the SAI and sensors myself, and let the dealer do the IDM
mole2002 is offline
post #15 of 23 (permalink) Old 10-20-2010, 11:18 AM
lipadj46's Avatar
Quoted: 0 Post(s)
The IDM should be easy enough to replace also
2002 DII 114,000 miles
lipadj46 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Warning Light on Dash won't clear 96 Disco rovinnaki Discovery Series I 4 07-07-2010 02:09 PM
2003 Disco 2 SE Lights on Dash LTD078 Discovery Series II 1 11-29-2009 11:53 AM
Landy Disco SII HSE 2003 V8 - DASH INDICATORS uhaditcomin Discovery Series II 1 06-29-2008 04:43 AM
Where to buy Dash kits for 2003 Disco? jarover Accessories 1 01-10-2005 06:43 AM
where to buy a Dash kit for 2003 Disco? jarover Discovery Series II 2 01-05-2005 12:58 PM
You may post new threads
You may post replies
