2003 Disco overheating - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 12-01-2012, 10:59 AM   #1 (permalink)
Fishkill Disco
Default 2003 Disco overheating
I have a 2003 Disco that overheats only when driving and after about a half mile. the system has been flushed and a new T-stat and hoses installed.
any thoughts
Fishkill Disco is offline   Reply With Quote
Old 12-01-2012, 03:54 PM   #2 (permalink)
A leak internal or external ,I can't see it from hear .
Blamo is offline   Reply With Quote
Old 12-02-2012, 06:22 AM   #3 (permalink)
Fishkill Disco
thank you, and if there is not leak or fluid loss, nothing in the oil or exhaust what would your ears tell you
Old 12-02-2012, 06:52 AM   #4 (permalink)
Administrator
How mechanical are you, how many miles on the engine and have you been needing to add coolant recently.
In the mean time do not drive it any more till this is fixed.
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 12-02-2012, 11:32 AM   #5 (permalink)
Given your description, it might be the fan clutch.
If I have one in stock, $100-shipped
P. T. Schram Rover Repair
Full-service independent Land Rover facility
I ain't got much a nothing at all, but I damned sure got it made. If you don't like the way I'm living, you just leave the silly Rover boy 'lone!
Yeah, my PM box is full. If you want help, need parts, are on the ledge and need to be talked back, e-mail me at PT@PTSchram.com or call me at 260-804-0458.
If you don't like my attitude, I really don't care, but I will help you fix your truck anyway.
PTSchram is offline   Reply With Quote
Old 12-03-2012, 02:54 PM   #6 (permalink)
Fishkill Disco
i am very mechanical when i have the time. 155k miles
i am not driving the Disco and i have not had any coolant problems prior to the incident.
she drove it till the engine started knocking and shut it down (so i was told)
i had it towed and drained the oil and coolant to see if anything was mixed and there is not. i replaced oil and coolant and let truck idle for 2 hours- still no mixing of fluids no overheating running fine. drove less than one mile and temp gauge shot to top. then replaced t-stat and flushed system. again idled for an hour no issues and drove 1 mile and same overheating
phone 585-287-3322
Old 12-09-2012, 08:48 AM   #7 (permalink)
Fishkill Disco
i would i confirm the clutch is bad
i have read after the engine is warm and then shut off the fan should not spin freely
if so, then my clutch is bad since the fan spins freely after shut down
Old 12-09-2012, 08:56 AM   #8 (permalink)
Fishkill Disco
from on=line reading (dangerous sources) I was testing today to see if the clutch is bad, i suspect it is. after shutting down the fan spins freely by hand. i know my electric fan is shot, tested and have voltage to the unit and then tried moving it and it is frozen.
let me know if you think this is the problem.
again idling in the driveway the temp is fine as soon as i drive around the block a couple of times it overheats. come back and let it cool down and do it again same results. watching temp gauge closely so i dont over do it.
thanks for the advice
2003 disco 2 overheating KANDELA Discovery Series II 12 08-21-2011 08:14 AM
size of hub centric rings for 2003 disco with 2003 hse wheels seamonkey1 Wheels and Tires 6 08-08-2011 06:25 AM
Overheating 2003 Freelander, fixes when I turn right. ctrygstad Freelander / LR2 7 04-05-2011 01:23 PM
2003 disco issues - instrument panel, AC stuck on high and overheating hackery Discovery Series II 8 07-09-2010 09:16 AM
Overheating issues on a 2003 Discovery LaRoDIs51 Discovery Series II 2 09-03-2009 05:28 AM
SEO by vBSEO 3.3.2
