Old 06-14-2008, 06:37 PM   #1 (permalink)
Default 2004 discovery runs hot
i have 2004 discovery 32k 1/2 hour ideling gauge shoots red like overheating replaced thermostat got correct anti freeze fans work help
jayfinn3 is offline   Reply With Quote
Old 06-14-2008, 08:05 PM   #2 (permalink)
Watch your pressurized coolant tank. If it seems to lose coolant, look for a radiator or hose leak.
tyl604 is offline   Reply With Quote
Old 06-15-2008, 05:42 AM   #3 (permalink)
So have you had to add coolant, did you bleed the system?
Does your heater blow hot when your engine is idling?
Old 06-16-2008, 01:09 PM   #4 (permalink)
Was the 30k mileage service completed at the dealer???
Could be the fan clutch is not working properly... It should spin with resistance when cold. When hot, it will also roar some and you can hear it from the passenger compartment... Does yours do this?
Maybe a clogged radiator...
same thing happened to me (but never went into the red zone) and the t/stat cracked and vent screw went bad... The heat from the idleing was making the temp. shoot up that high (the hot air from the idle does not flow well unless the vehicle is moving)... Best bet is not to let any vehicle idle for more than a few minutes...
jmrivera is offline   Reply With Quote
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
Looking to buy a 2004 Discovery want2buyDiscovery Discovery Series II 6 04-08-2005 07:12 AM
Discovery 2004 HSE Leaking from Back Door agreenway Discovery Series II 2 09-30-2004 12:10 PM
Should I wait until the LR3 is out to purchase a 2004 Discovery? tono Discovery 3 / LR3 4 09-20-2004 08:50 PM
2004 Land Rover Discovery drcraigmjonees Land Rover Vehicles 0 08-11-2004 09:45 PM
