Old 11-26-2006, 10:52 PM   #1 (permalink)
Default 3" OME Lift
Let me introduce myself, I have an 04 disco and want to go with a 3" lift. I've been lurking around this forum and DiscoWeb for awhile and i am deciding to go with OME lift over RTM. I plan on getting:
-751's in front
-763's in rear
-N107's in front
-N108's in rear
-OME steering Damper
-BFG 265/75 R16
Reading a post at DiscoWeb about the RTE 3" kit someone said-
Originally Posted by PHARAOHDISCO
It's a large project you are undertaking, it's not only a set of springs and shocks and four tires. You will need much more to perform a 3" suspension lift properly. As a start you will need the following parts:
1) Front double cardan driveshaft
2) Rear U-jointed Driveshaft
3) Extended castor corrected front radius arms
4) Rear extended trailing links
5) Extended brake lines, front and rear
Now do i need to add the DC driveshaft, rear u-jointed DC, radius arms, trailing links, etc? or does this only apply to the RTE lift?
thanks,
steve
stevogabe is offline   Reply With Quote
Old 11-26-2006, 10:59 PM   #2 (permalink)
rmuller's Avatar
for the most part you do not need to do any of the extras for the OME 3" ... the RTE 3" sits higher than the OME and a lot of people have been successful with the OME 3" and no additional mods.
Old 11-26-2006, 11:33 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
True!! But is a good idea to do it all........ You don't "HAVE TO" but it makes for a smoother running rig!
Old 11-28-2006, 05:21 PM   #4 (permalink)
what are the specs on your lift? did you end up doing those extra mods?
Old 11-28-2006, 05:38 PM   #5 (permalink)
I have that lift. 3" OME on my 99 D2 running 265's, never had to make any corrections for the lift. Any tall and you will though.
