Old 03-02-2006, 11:16 PM   #1 (permalink)
nice member
Default 52K service
what does the stealership do at 52K service interval, 01 D2=out of warranty
with 50K+ miles on truck,light off road+ winter snow driving
what do they replace at the this service besides engine oil
i changed oil at 50425, service book says due at stealership at 52K
was wondering all the things they look for and or replace at this time?
also thanks disco mike for the K&N oil filter tip, will use on me next oil slap
REFERJOHN is offline   Reply With Quote
Old 03-02-2006, 11:20 PM   #2 (permalink)
rmuller's Avatar
52,500 MILE SERVICE
Exterior
Add 16 oz Land Rover Fuel Conditioner (LRN5010)
Inspect wiper blades
Under Vehicle
*Change engine oil and replace filter
Inspect tire pressures, condition and tread depth
Inspect brake pads, calipers and discs
Record performance of Service in Passport to Service
60,000 MILE SERVICE
Exterior
Lubricate door locks, check straps
Lubricate hood latch and safety catch, fuel door hinges
Replace Alarm handset batteries
Interior
Check parking brake (Adjust if necessary)
Check seat belts
Under Hood Inspect coolant hoses
Inspect radiator and AC condenser
Check power steering fluid level/ACE fluid level
Clean battery and terminals
Inspect serpentine drive belt
Change brake fluid
*Replace air-cleaner element
Change engine coolant
*Replace spark plugs
Under Vehicle
Perform body corrosion warranty inspection
Inspect exhaust system and heat shields
Inspect brake lines
Lubricate drive shafts and U-joints
Inspect steering rods, joints and dust covers
Inspect shock absorbers
Inspect suspension links and mountings
Inspect trailer hitch attachment bolts for tightness
Inspect wheel speed sensor and height sensor wiring
Inspect fuel and hydraulic lines
Change transfer gearbox oil
Change transmission fluid
Check front and rear axle oil level
Service SLS filter (if equipped)
Old 03-03-2006, 08:37 AM   #3 (permalink)
Other then what was mentioned already, and not knowing what has been done in the past, I would suggest you look at changing,
Power steering fliud
Brake Fluid
When you hit the 60K is when you will do your first full tune up as well as all fluids.
