Old 01-18-2006, 05:45 AM   #1 (permalink)
JamesVee's Avatar
Default '99 DII Blinker Problems
Any ideas here guys? The blinkers arent' working. Everything else seems to be working fine.
Check out my websites: Family Trophies and Africa Pictures
JamesVee is offline   Reply With Quote
Old 01-18-2006, 07:26 AM   #2 (permalink)
You could be a little more specific. Do they not flash, too slow,too fast, not at all. Do they light up, do they have power to them?????
Give us something to work with.
Mike J.
Old 01-18-2006, 08:37 AM   #3 (permalink)
JamesVee's Avatar
Thanks for the inquiry, Mike. They have started to work again now. When the truck is cold the blinkers dont want to work at all. No lights, no flashes, no clicks, nodda.
Old 01-18-2006, 10:14 AM   #4 (permalink)
Super Moderator
02disco2's Avatar
Sounds like a blown fuse, just had the same problem myself.
Land Rover-less.
2006 Infiniti QX56 - Loaded
2002 Discovery II SE - SOLD!
Old 01-18-2006, 11:11 AM   #5 (permalink)
Don't you just these trucks???
If the cold is causing this to happen, then you could be looking at a bad connection, fuse or the switch. This will be one of those interesting ones I am afraid.
Mike J.
Old 01-18-2006, 12:50 PM   #6 (permalink)
psg
I had a similar problem, my signals were very slow to start blinking when it was cold. Took the signal swithch off, took apart the back of the switch where the plug ins go and cleaned the contacts and replaced the dielectric grease, the contacts looked fine but the grease was dirty around the contact points. Now they work perfectly even in -30C.
psg is offline   Reply With Quote
