does anyone know what this might be. One person said that my brakes just might need to be blead. if anyone has any ideas or had this problem any help would be useful
2000 Disco II
2000 Land Rover Disco II 1969 Ford Mustang (under resto) |
just had the same problem, same year disco also. It was the driver side ABS sensor line, it is a $80 part, 2hrs of labor, plus the diagnostic charge from the dealer to figure out what sensor it is.
![]() Join Date: Jun 2005
keep an eye on it, and take note of the weather when it comes on. I had a senor with a crack in it that became a problem when ever it got wet.
"Ish...I have in the past mistaken you for a perverted shit bag...now I realise that I am not shit bag enough. You truly are a king among men.I am not worthy with such imagination." Series 3 Guy 2005 Range Rover HSE 2007 BMW X3 M Sport Pkg 1990 911 Cabrio triple black 2006 Mini Cooper S Checkmate - GONE 1987 Corvette - 18 yrs Gone,,, sniff sniff - |
TEAM GREEN
mine has hill decent,traction,abs lights all on yellow, mine when i stop hard in grass tha driver side front wheel is the only wheel to slide, i think it is that speed sensor, $212.00 from land rover, or $169.00 from atlantic british, should odre next week will let yall know if works.
Don't try and guess what caused the ABS and T/C light to come on, it can be many things all of which can only be diag. by a scanner. This can happen when your brakes run hot and fade, dirty brake fluid, bad sensors, bad connections up to a bad modulator assembly.
How long has it been since you had your brake fluid changed?? Good place to start, fast and cheap and will clean out stuck valves in the control unit. Mike J. |
#9 (permalink) |
Richard
There can be many things:
Brake Fluid, Bad Brakes, Hub, Shuttle Valve, Modulator, ABS sensors, etc. Only way to know is have codes downloaded. Cheap OBDII code reader won't work, you have to have Notebook. |
#10 (permalink) | |
Proud to be an Infidel
MEEKROL you never did come back with a post to say what the problem was.....
2001 Disco SE7 .......eventually they will run out of suicide bombers..... |
#11 (permalink) |
flywheel it wont have any effect. you need the code to have it properly diagnosed.
The code gives you a guide to start diagnosis. Its like trying to get somewhere on a train. you need to know what track the train is going to be on to get to the destination. |
#12 (permalink) |
ABS, T/C and Hill Desent can all come on because of either a bad sensor, brake pad chatter when over heated, burned brake fluid or simply because you nailed them hard a couple of times and the sensors picked up too much wheel sliding.
When was the last time you changed your brake fluid, this can be the number killer of the ABS unit?? Mike J. |
#13 (permalink) | ||
Thanks again Mike.
#14 (permalink) |
If it went off when you turned the key its possible it could be the shuttlevalve.
basically go to all the grounds in the front by the air box in the front and remove the nuts and clean the stud and wire and then tighten it back up. There are two others on the passenger side by the fuse block. Then you can go to the driverside kick panel inside the vehicle and remove the panel and there is one more ground you can clean. If it goes off and stays off then you know its cured. Basically the shuttlevalve gets a bad ground sometimes. ANyway if it doesnt get it diaged and go from there. |
#15 (permalink) | |
A slight correction to my prior post..the last service was at 45K. Thanks again Beezel. I will check those ground connections at first chance.
| Thread Tools | |
| Display Modes | |
