well i for one have replaced 2 bad sensors in my truck both fronts, ordered the sensor its self from the dealer and they questioned me about it and i said it was the only thing left and it did fix my three amigos situation...
the rave does not break the parts down but the dealership parts counter does.. its just a 4 or 6 mm allen head screw on the top of the hub... and then follow the wires...
make sure you order and get your new ones before you start so you know how far you will have to go... my new front sensors had to be wired into the ecu harness which was pretty easy...
03 Land rover disco 2 -- ARB bullbar w/warn m8000, Custom rear bumper, 04 CDL installed, Muffler removed, 16" Steel rims 235/85 Destination MT's, Spare tire moved to load space, Pioneer radio, OME 2inch HD lift, Front and rear TruTrack diffs, scangauge2.
12 Mercedes-benz ML350 BlueTec 28-mpg
12 VW Touareg TDI Executive 30-mpg
