ACE sway bar bushings - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 15 (permalink) Old 01-10-2013, 06:03 AM Thread Starter
Quoted: 0 Post(s)
I have a couple sources of clunks that i have found so far.
I have to replace my from ACE sway bar bushings. Do just have to unbolt the two brackets and replace the bushings? The bar shouldn't be loaded because the DII will be level (side to side). I plan on doing it with the DII on the ground. Is there any thing I am missing?
My Watts linkage bushing are next. One of them is shot. I figure I should do all of them if I have the linkage out. I ordered them form the UK and saved a bunch of $$. They were $112+$30 shipping (got them the next day). I also got the ACE filter for $25 (vs $50 in the US)
99 DII - base (doesn't run)
00 DII - Winter pkg, ACE, SLS, 7 seater, sunroofs.
acamato is offline
post #2 of 15 (permalink) Old 01-10-2013, 06:07 AM
Administrator
Quoted: 5 Post(s)
Have you tested the ACE bushings to verify they are bad, it is very rare when they fail even though the may look bad.
If you are getting a noise from them spray both with silicone and see if the noise goes away.
How many miles on your truck?
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #3 of 15 (permalink) Old 01-10-2013, 08:03 AM Thread Starter
Quoted: 0 Post(s)
104K. They are shot, I was able to wiggle (up/down) the bar in the bushings. When I do that, I do get a clunk sound. I checked the rear bushings and they are good, no movement at all.
acamato is offline
post #4 of 15 (permalink) Old 01-10-2013, 10:37 AM
Administrator
Quoted: 5 Post(s)
Make sure to unplug the power scourse for the ACE so it will slowly bleed down pressure which will allow you to mover that arm, a little.
Need Parts?
Lucky8,
post #5 of 15 (permalink) Old 01-10-2013, 07:43 PM Thread Starter
Quoted: 0 Post(s)
I swapped them out tonight. It took all of 20 minutes. I didn't have to pull the fuse for the ACE. One of the clunks is gone. No I just have the one from the Watts linkage. Hopefully I can do that this weekend.
acamato is offline
post #6 of 15 (permalink) Old 01-11-2013, 03:45 AM
Administrator
Quoted: 5 Post(s)
If you haven't done it yet, consider flushing your ACE, will make it work better.
Need Parts?
Lucky8,
post #7 of 15 (permalink) Old 01-11-2013, 03:52 AM Thread Starter
Quoted: 0 Post(s)
Mike, that is on my to do list. I am slowly working on the major maintenance list that you posted. I have the fluid and a new filter. Just need the time to do it.
acamato is offline
post #8 of 15 (permalink) Old 01-11-2013, 06:10 AM
Administrator
Quoted: 5 Post(s)
You might want to call me before you do the filter, it can be a pain sometime.
Need Parts?
Lucky8,
post #9 of 15 (permalink) Old 01-14-2013, 06:54 AM Thread Starter
Quoted: 0 Post(s)
I replaced the Watts linkage bushings/bearings yesterday. What a difference. Between the sway bar bushings and the Watts linkage bearings the knocks and clunks are gone.
acamato is offline
post #10 of 15 (permalink) Old 01-14-2013, 06:55 AM Thread Starter
Quoted: 0 Post(s)
What should I replace first? filter or fluid?
Anything I need to know in addition to the info here: http://www.discovery2.co.uk/ACE_Filter.html
acamato is offline
post #11 of 15 (permalink) Old 01-14-2013, 07:53 AM
Administrator
Quoted: 5 Post(s)
Filter, but pull it out and quickly replace the filter with out loosing too much fluid, keep th old filter, it can be cleaned and reused later.
Do you know how to flush the system?
Need Parts?
Lucky8,
post #12 of 15 (permalink) Old 01-14-2013, 08:00 AM Thread Starter
Quoted: 0 Post(s)
Yes, I came across a few posts where you explain how to to flush the system.
acamato is offline
post #13 of 15 (permalink) Old 01-14-2013, 08:19 AM
Administrator
Quoted: 5 Post(s)
You will find you will probably need 3 to 4 quarts of p/s fluid and if the steering hasn't been done recently I would suggest doing it at the same for a total of 7 or 8 quarts between them.
Need Parts?
Lucky8,
post #14 of 15 (permalink) Old 01-16-2013, 05:02 PM Thread Starter
Quoted: 0 Post(s)
I have 2 gals of PS fluid along with the Lucas additive. I hope to get to it this weekend.
acamato is offline
post #15 of 15 (permalink) Old 01-17-2013, 04:46 AM
Administrator
Quoted: 5 Post(s)
Good luck with it, you should feel a difference real quick. You might hold off or use no more then 1/4 bottle of the Lucas because of the cold weather, otherwise the p/s pump will growl at you and a really cold morning, only for 3 or 4 seconds, then it is fine.
Need Parts?
Lucky8,
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Sway bar bushings? CRJ Discovery Series II 1 09-04-2012 05:12 PM
Front end sway bar bushings? Bmwm7 Range Rover P38, Mk III and Range Rover Sport 0 01-16-2012 04:58 PM
Front Sway Bar Bushings jseufert Discovery Series II 2 10-31-2011 11:54 AM
sway bar the rig Discovery Series I 12 01-13-2010 03:48 AM
ACE Bushings wimp Discovery Series II 4 05-30-2008 03:32 PM
You may post new threads
You may post replies
