Old 04-14-2005, 09:37 AM   #1 (permalink)
John's Avatar
Default Alarm Sensitivity
04 D2HSE
Is it possible to adjust the sensitivity of the alarm system?
We have had a couple of heavy hail storms recently that have set it off.
John is offline   Reply With Quote
Old 04-17-2005, 09:04 AM   #2 (permalink)
Default Don't know about the D2, but . . .
I had a local car security company "de-sensitize" the system on my 96', they did a great job. It was so sensitive when I got it that the wind would set it off. You couldn't stop the vehicle and set in it without opening a door or the alarm would arm itself after 90 seconds, lock down, and go off. You couldn't stick your arm through an open window to set your lunch box inside without setting it off. It drove me nuts! With yours being an 04', I would start @ the dealership as they will probably have to connect it to testbook to reset the alarm parameters. Good luck, hope you get it figured out. LRW
LRWheelman is offline   Reply With Quote
