In the dark, every chance I get...
I recently had my front end aligned because I got new tires and the ones that were on it this winter when I bought my D2 were badly worn on the inside of the front tires. The mech said the LR specs on alignment were .17 for toe, slightly pointing the tires outward and wondered if that was why the tires wear on the inside. He set the front end to .14 and told me to check around and bring it back for a redo if neccessary.
What's the reason for outward pointing tires? Anyone with spec alignment having tire wear problems?
Regards, SpeleoRover '00 LR Discovery II OME HD 2", 267/75R16 BFG TA KO's & All the cave gear and coffee I can haul
Not sure if my truck has had a alignment in it's life so far [as i am the second owner] but i suspect that it is set up to factory specs....no excesive tire wear. The out ward toe angle will give more directional stability [in other words allow the vehicle to drive straighter ]...gives a bit better turn in ability. They will always tell you that toe is not a tire wearing angle [not really true but].......
How were your camber specs??? if the tires were worn to the inside i would be looking at them first..... |
My camber was dead on factory specs at .20
wrong,
two adjustments, front toe and steering angle. front toe can be on and still pull because of steering angle. likewise it will go down the road straight but wear tires like a bastard. camber cant be adjusted. hell you can use a piece of string to adjust toe. oh and only the independant suspension vehicles can have the other adjustments set. oh and camber wears tires, caster doesnt but does cause a pull. toe wears tires but it goes out almost all the time. rarely can you find a vehicle that you set the toe on thats not off on an independant suspension vehicle like an LR3
Alignment specs are TOW OUT = minus 0 degree, 10 minutes which means a tow IN of 0.17 degrees. The track rod adjusts tow-in - the one behind the axle.
Brian 2004 Discovery II G4 Edition 2002 Freelander SE - Gone! Formerly HMBFreelander |
I have to confess my complete ignorance when it comes to alignment angles. I've been doing a little reading on it though. I trusty my guy - alignments are the fattest part of his business. I think I misunderstood the direction of the toe.
Wait 'n' see... ![]()
