Alternator Removal - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 7 (permalink) Old 02-17-2010, 05:35 PM Thread Starter
W7412R's Avatar
Quoted: 0 Post(s)
Alternator Removal
Ok, now I'm trying to get the ALT off and after removing the two bolts which hold it in place on its bracket, It still doesn't come off. It appears to have two bushings which the bolts slide thru on the front of the ALT bracket. Alternator is still stuck in place and won't budge.
Can anyone tell me how to remove the bushings or do I just apply more force to remove the ALT.
Thanks!!!
Also, I finally disconnected the throttle/Cruise Control cable from the cam near the throttle body, but I can't figure out how to get the cable off from the end where it's secured in place by two 13mm nuts.
At this rate, it's gonna take me a month to get this head gasket job done.
Sheesh!!!
W7412R is offline
post #2 of 7 (permalink) Old 02-17-2010, 05:37 PM
rmuller's Avatar
Quoted: 0 Post(s)
I've always had to wedge the alternator out after removing the bolts... there is a bit of space on the right hand side of it to get a prybar/big screwdriver/back of a breaker bar and lift up on it.
Ryan ::
2001 Discovery II | 2006 LR3 HSE7 | 1994 Defender 90 #416 (Gone)
rmuller is offline
post #3 of 7 (permalink) Old 02-17-2010, 05:47 PM Thread Starter
W7412R's Avatar
Quoted: 0 Post(s)
Ok Great!!! Thanks for the info!!! Do you by chance know how to disconnect the cruise control/throttle cables from the screw area where it attaches to the intake?
W7412R is offline
post #4 of 7 (permalink) Old 02-17-2010, 05:53 PM
rmuller's Avatar
Quoted: 0 Post(s)
lift them up so the tension is loose then slide that littler cylinder out of the hole
Ryan ::
rmuller is offline
post #5 of 7 (permalink) Old 02-17-2010, 05:54 PM Thread Starter
W7412R's Avatar
Quoted: 0 Post(s)
ya, but what about the other end where there are two 13mm screws which lock the cables onto the bracket in front of the intake area. I got that little pin out of the cylinder this morning.
W7412R is offline
post #6 of 7 (permalink) Old 02-17-2010, 05:59 PM
Back in a Series LR after 25 years :-)
slouzon's Avatar
Quoted: 0 Post(s)
Unscrew the nut past the undercut in the threads and slide the undercut area through the opening in the bracket.
Steve
Back in a LR after 25 years!!!
71 Series IIa 88
01 D2, 2" lift, CDL. RTE front bumper with 9500# Ramsey winch
"BackInA88" on all the other LR forums
(Sign up here first and couldn't think of a good handle at the time!
slouzon is offline
post #7 of 7 (permalink) Old 02-17-2010, 06:19 PM Thread Starter
W7412R's Avatar
Quoted: 0 Post(s)
ahhhh, ok...makes sense now. Then I can just place them out of the way until I need to reconnect them? THanks a lot!!! I appreciate the help!!!
W7412R is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Which Alternator? texasdiver72 Range Rover Classic 4 02-18-2010 05:05 PM
Alternator removal and installation jlgolson Discovery Series II 3 01-14-2010 06:52 PM
Removal of alternator 97 Disco.... timkel74@msn.com Discovery Series I 2 10-12-2007 01:44 PM
Alternator bracket removal?!?!? Kevin88RRC Range Rover Classic 6 05-31-2006 04:24 PM
is my alternator going? Bene Discovery Series I 18 04-28-2006 12:25 AM
You may post new threads
You may post replies
