Links
Old 01-10-2006, 07:44 PM   #1 (permalink)
Roads?...Where we're going, we don't need roads...
keptin's Avatar
Default Any tips for adding Extended brake lines....(brake fluid bleed tips)
Any tips/info/specialty tools I should be aware of?
This comming sunday a friend's dad and I are putting on lift #2 and starting with the extended brake and ABS lines. We have a copy of RAVE to use....seems simple enough. I dont trust local places anymore....they do too much damage.
Also....the info on the RAVE CD says not to mix brake fluid brands. Is it ok to? What is the standard brand of DOT 4 brake fluid for DIIs?
Josh Shapiro
DII
Photos at www.kep1.com
Old 01-10-2006, 09:27 PM   #2 (permalink)
Otherwise known as STEVE
Use gravity to bleed out the lines as best you can... don't use a power bleeder. Don't let air into the reservoir end or you'll need a testbook or autologic to bleed the system.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
