Bad Gas Symptoms - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 10 (permalink) Old 02-08-2012, 04:08 PM Thread Starter
Quoted: 0 Post(s)
Bad Gas Symptoms
Guys,
I dont want to just jump the gun and say that I think I have bad gas but I am surely having the symptoms of so. I got gas the other day a pretty low volume station and put premium in it. About 3 miles later going down the highway my check engine light started flashing and the truck started sputtering real bad under load, and at idle. The truck seems to just be missing real bad and its just weird that it was an all of a sudden thing while driving. I have let the truck sit for the past 2 days until I could get around to messing with it and I put in a fuel additive that reduces water content and ups the octane. It started up fine and I took it to a close gas station and filled it up with premium and I drove it another 2 miles or so hoping that this would solve the issue ... no such luck.
So here is my question. Is a 2 mile drive far enough to get fresh fuel in the tank to the motor. Next what else could cause these issues? I initially thought bad plugs and or wires but I just replaced those about 5K miles ago. Any ideas on what else it could be or is there any chance I just have not given enough time for fresh fuel to get to the tank. I have not had the chance to make it to the mechanic to get the codes pulled, I guess I will do that this weekend.
Thanks
Spyder7892 is offline
post #2 of 10 (permalink) Old 02-08-2012, 04:56 PM
cdeuso's Avatar
Quoted: 0 Post(s)
I got bad gas not too long ago. My symptoms were not nearly as bad as yours. Mine was only missing slightly under load. The CEL never came one. I ended up adding 2 bottles of HEET to the tank and that seemed to clear mine up. I also tried topping it off every little bit to try and dilute the bad gasoline.
'03 Discovery- front driveshaft rebuilt, OME 751 & 762 w/ Terrafirma HD Shocks, ProComp 265/75 16 Mud Terrains, 4.11 HD gears, Rear Detroit, rear 1.5" spacers, F & R diff guards
'06 Mustang GT- the daily driver
cdeuso is offline
post #3 of 10 (permalink) Old 02-09-2012, 05:36 AM
Administrator
Quoted: 5 Post(s)
How much gas was in the tank before filling and how much did you put in?
Get your codes read and get back to us with the fault code numbers?
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #4 of 10 (permalink) Old 02-09-2012, 02:59 PM Thread Starter
Quoted: 0 Post(s)
The tank was quite low, the light had just come on, and I put in about 8 gallons. I later added the fuel additive after the issues started and filled the tank the rest of the way with premium. I will get codes this weekend.
Thanks
post #5 of 10 (permalink) Old 02-11-2012, 11:53 AM Thread Starter
Quoted: 0 Post(s)
Alright guys, I have a Cylinder 5 misfire code, Cylinder 8 misfire code, and a multiple cylinder misfire code. Any ideas guys, still think it could be bad gas even with the additive and filling up the rest of the way with good fuel?
post #6 of 10 (permalink) Old 02-11-2012, 12:20 PM
Administrator
Quoted: 5 Post(s)
How many miles on the engine, when was it last tuned along with 8 mm silicone wires.
Bad gas will usually cause more or all cylinders to misfire so I am leaning toward a tune up.
Need Parts?
Lucky8,
post #7 of 10 (permalink) Old 02-11-2012, 01:47 PM Thread Starter
Quoted: 0 Post(s)
The motor has 145K on it. Plugs and wires were done less than 10K ago with magnacore 8mm's and I dont remember which plugs but they came highly recommended on the forum. What does the multiple random misfire code mean, does that just cover the two cylinder misfires that are specified by other codes, or can it mean any number of the cylinders
post #8 of 10 (permalink) Old 02-11-2012, 05:27 PM
Administrator
Quoted: 5 Post(s)
"yup"!
Need Parts?
Lucky8,
post #9 of 10 (permalink) Old 02-11-2012, 06:32 PM Thread Starter
Quoted: 0 Post(s)
can you elaborate on that Mike? Do you still think it could be a wires problem even though they aren't that old?
post #10 of 10 (permalink) Old 02-12-2012, 03:17 AM
Administrator
Quoted: 5 Post(s)
PM me your number and I'll call you.
Need Parts?
Lucky8,
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Symptoms of a bad Catalytic Converter 98GRDisco Discovery Series I 6 06-17-2015 11:13 AM
Bad gas or something worse? mckeehan6419 Discovery Series II 6 10-28-2010 04:36 AM
symptoms of bad O2 sensor and Vacuum Advance? parkpy Range Rover Classic 3 02-03-2010 01:09 PM
Symptoms of bad injectors mll Range Rover Classic 1 09-09-2007 11:20 AM
what are the symptoms of a bad MAF sesnor? deadboy1977 Range Rover Classic 3 09-04-2007 04:22 AM
You may post new threads
You may post replies
