Boatload of ABS Codes - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-10-2012, 06:53 PM   #1 (permalink)
Default Boatload of ABS Codes
Hi all. My ABS Amigo has given me a ton of codes and I have no clue where to begin with this. Should I replace all the wheel speed sensors independently? Replace ABS unit? Shuttle valve (although 114 is one of the few codes I DIDN'T get)? Any advice on where to begin? I am a complete n00b.
Here is the ABS Amigo output:
-----ABS Amigo Box V1 RSW Solutions LLC Copyright 2010-----
|* The information provided is without warranty of any kind.*|
|* IN NO EVENT SHALL RSW Solutions BE LIABLE FOR ANY LOSS OR*|
|* INJURY OR DAMAGES resulting from or connected to use of *|
|* this Information or Product. YOU HEREBY WAIVE ANY AND ALL*|
|* CLAIMS AGAINST RSW Solutions ARISING OUT OF YOUR USE OF *|
|* THIS INFORMATION OR PRODUCT. *|
1.--Current Faults---->
Active Faults:
None
Logged Faults:
Front Left Sensor Bad Output
<-END Faults
..--Previous Faults--->
Active Faults:
032:Front Left in valve open circuit
036:Rear Left in valve open circuit
057:Rear Left out valve short to Gnd
061:Brake light relay short to Gnd
066:Front Left sensor electric fail
067:Rear Right sensor electric fail
072:Front Left in valve short to supply
Front Right Sensor Bad Output
Rear Right Sensor Bad Output
091:Front Right out valve drive short to Supply
093:Front Left out valve drive short to Supply
096:Rear Left in valve drive short to Supply
101:Brake light relay drive short to Supply
110:Sticking throttle
Comms Error
Logged Faults:
Comms Error
<-END Faults
Active Faults:
None
Logged Faults:
None
<-END Faults
2003 Discovery II V8, 105,000 miles
slaphappy is offline   Reply With Quote
Old 11-10-2012, 07:04 PM   #2 (permalink)
Administrator
I believe you also posted on the LRF, go read and follow my directions.
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 11-10-2012, 08:02 PM   #3 (permalink)
Sorry, but it wasn't me. Would love to read your advice though, particularly if the person on the other forum had similar issues. Do you happen to have a link to that thread? Thanks
Old 11-11-2012, 05:43 AM   #4 (permalink)
Administrator
Sorry, there was another, near exact post on the LRF. First go clean and tighten you battery cable and grounds, then have a local parts store do a free charging system test, your voltage has to be between 13.6 and 14.4 volts.
If all is well, then clear your ABS codes a couple of times and see what new ones show up.
Need Parts?
Old 11-11-2012, 11:26 PM   #5 (permalink)
Thanks Mike. Will do. I tried to test the voltage myself with a multimeter. Granted that I have no clue what I'm doing, it looked to me like the voltage was about 13.9 with the engine running and about 12.6 with the engine turned off. But like I said, I don't really know what I'm doing so I will take it someplace to have the charging system checked.
To help me understand what I'm doing, is the theory here that if the charging system is not operating properly, then electrical weirdness could be causing all the above error codes together rather than each one being caused individually by an underlying part issue?
Old 11-12-2012, 05:28 AM   #6 (permalink)
Administrator
Looks like your voltage is OK so clear the code, and drive it till they come back then get back to me with the new codes.
Need Parts?
Finaly got ABS codes. Now what? 03DISCOHP Discovery Series II 10 06-22-2012 04:50 PM
ABS Amigo Codes....what do they mean? Redvalley Discovery Series II 5 01-09-2012 01:23 PM
Need help with ABS Amigo Codes adamgrn Discovery Series II 5 12-15-2011 04:10 PM
Pulled the ABS Codes with my new ABS Amigo j.haffly Discovery Series II 7 09-07-2011 05:00 PM
ABS codes read mtd77246 Discovery Series II 3 12-31-2008 11:05 AM
SEO by vBSEO 3.3.2
