Braided Stainless Steel Brake Hoses/Lines - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 10 (permalink) Old 08-05-2013, 06:38 AM Thread Starter
j887276's Avatar
Quoted: 0 Post(s)
Exclamation Braided Stainless Steel Brake Hoses/Lines
My 2001 Discovery II has about 130,000 miles on it and the brakes feel a little "soft." It has new front and rear pads and rotors and had the fluid flushed at the same time. The brakes still feel "soft." Obviously with 130,000 miles the original stock rubber brake hoses have worked well but have some wear on them.
Instead of replacing the brake hoses with OEM rubber hoses, would the stainless steel braided hoses be a better choice? This vehicle is a daily driver, but occasionally does see some light off-road driving.
Anyone here running stainless steel braided brake lines? How are they compared to stock on our vehicles for both on-road and off-road use? Pros/Cons?
Thanks.
j887276 is offline
post #2 of 10 (permalink) Old 08-05-2013, 06:54 AM
Administrator
Quoted: 5 Post(s)
Who's pads are you using?
There are 6 rubber hoses that you should replace, 1 on each caliper and 2 under the master cylinders. These will make a huge difference giving your a firmer brake pedal and a little better stopping power.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #3 of 10 (permalink) Old 08-05-2013, 07:15 AM Thread Starter
j887276's Avatar
Quoted: 0 Post(s)
Thanks Mike, what are the two under the master cylinder called? Why are they rubber?
Any thoughts on the braided stainless steel brake hoses?
I am using OEM Land Rover pads.
j887276 is offline
post #4 of 10 (permalink) Old 08-05-2013, 08:27 AM
Administrator
Quoted: 5 Post(s)
Stain less steel is the best, and if you want to do it right you have to replace the two under the booster mounted on the fire wall.
ID:	41129   Click image for larger version
ID:	41137   Click image for larger version
Need Parts?
Lucky8,
post #5 of 10 (permalink) Old 08-09-2013, 12:31 PM Thread Starter
j887276's Avatar
Quoted: 0 Post(s)
Thanks Mike. Where can I buy just the two braided SS lines for under the booster?
Why are these lines rubber anyways? Can they just be replaced with standard brake tubing?
j887276 is offline
post #6 of 10 (permalink) Old 08-09-2013, 05:29 PM
Administrator
Quoted: 5 Post(s)
I'll have to go back thru some paper work and see if I can find the information.
Need Parts?
Lucky8,
post #7 of 10 (permalink) Old 08-09-2013, 06:37 PM
Quoted: 0 Post(s)
AB has then for sale individually.
Brake Flex Hose Connects Between Modulator And Pipe (SHB101350SS Same Fit As Part # SHB101350) - Land Rover hoses from Atlantic British
2003 SE7 135K miles - Rebuilt engine with RPI stage 3 heads piper torquemax cam. Ceramic coated manifolds and Magnaflow exhaust.
Plov is offline
post #8 of 10 (permalink) Old 08-10-2013, 11:48 AM
Quoted: 0 Post(s)
Disco Mike. Your brake lines look like really nice pieces. What brand are they and where did you get them?
Thanks!
Mark633CSi is offline
post #9 of 10 (permalink) Old 08-10-2013, 03:07 PM
Administrator
Quoted: 5 Post(s)
Tactical Rover handled these.
Need Parts?
Lucky8,
post #10 of 10 (permalink) Old 08-10-2013, 03:13 PM Thread Starter
j887276's Avatar
Quoted: 0 Post(s)
Thanks!
They are just typical coated SS hoses, but in a pretty red color.
The engineering and testing, which is what makes a truly nice braking component cannot be seen in pictures.
2001 Discovery II
j887276 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
RRC extended stainless steel brake hoses ArmyRover Land Rover Parts and Accessories 1 11-16-2012 04:42 PM
braided brake lines? dbro412 Discovery Series I 10 12-18-2008 09:21 AM
RRC parts FS: longer stainless brake hoses, manuals, trailer wiring, LWB floor mats kiato4 Land Rover Parts and Accessories 4 11-04-2008 06:45 AM
Installing stainless brake lines on P38A? NoExpert Range Rover P38, Mk III and Range Rover Sport 0 09-08-2007 05:28 AM
Goodridge stainless brake lines oberdahill Accessories 4 01-16-2006 05:13 PM
You may post new threads
You may post replies
