Brake fade? - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 8 (permalink) Old 12-19-2010, 08:12 PM Thread Starter
jwarn11's Avatar
Quoted: 0 Post(s)
Brake fade?
Hey everyone,
Quick run down of my previous problems leading up to the last week..
00 Disco II 149k miles.
A couple of months ago I had the rear passenger hard line break/rust through along the frame under the drivers side rear passenger door. No brakes!
Had it towed to my local LR dealer, they repaired the line. Brakes seemed soft when leaving the dealer. Returned and informed the service manager that they were now softer than they had ever been. Tech takes the disco, comes back and gives the default "they're good for a disco". I explain that they were much firmer before the rupture. They re-bleed the system and send me on my way. Still too soft. I ask for another re-bleed, they take the disco back and bring it back feeling the same. Service manager assured me that they used "testbook"?? to bleed the system, blah blah blah.
I'm not a mechanic by any means, but PT was kind enough to talk me through bleeding the system myself, and I've had a great, firm pedal until last week.
We had some freezing rain one day that gave the abs and TC a really good work out. That day however, the brakes started acting up. It stops without a problem, but while sitting, the pedal fades down. I can pump the brakes and the pedal still fades. I've crawled underneath it and see no leaks, and the master is full.
Any ideas? This just started after the freezing rain caused the abs and tc to kick in, it's been fine since the dealer repair (and me bleeding the brakes) a couple of months ago.
Happy Holidays
James
jwarn11 is offline
post #2 of 8 (permalink) Old 12-20-2010, 04:33 AM
Administrator
Quoted: 5 Post(s)
Master cylinder is most likely by-passing and will need to be replaced. Don't have the dealer do, we can walk you thru it.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #3 of 8 (permalink) Old 12-20-2010, 05:27 AM Thread Starter
jwarn11's Avatar
Quoted: 0 Post(s)
Is it possible that there was air in the abs pump that got pumped out into the system during the ice driving, or is fading only caused by a bypass leak?
I ask, because back when the line broke, the resevroir was empty by the time I got it stopped and off the road.
jwarn11 is offline
post #4 of 8 (permalink) Old 12-20-2010, 05:44 AM
Administrator
Quoted: 5 Post(s)
No, air in the module won't cause a problem at a stand still.
Need Parts?
Lucky8,
post #5 of 8 (permalink) Old 12-20-2010, 06:32 AM Thread Starter
jwarn11's Avatar
Quoted: 0 Post(s)
Thanks Mike,
One more question...
If there was air trapped in the pump, that was then pumped out into the brake lines when the abs activated for the first time since the repair was made, air would then be in the lines. Can air cause fade or just the spongy feeling?
I'm all for replacing the master cylinder if that's what it needs, but just want to be sure if it needs it, or just a good re-bleed.
I'm going for differential diagnosis here. Seems like there is a correlation between the fade and the pump activating for the first time.
jwarn11 is offline
post #6 of 8 (permalink) Old 01-04-2011, 04:33 AM
SCUBA Instructor
WetDawg's Avatar
Quoted: 0 Post(s)
Fixed?
Did you ever find a resolution for your fading brake issue?
All beings form habits of action influenced by subjective feelings and affections based on ignorance of the essence of awareness.
Chinul
WetDawg is offline
post #7 of 8 (permalink) Old 01-04-2011, 05:10 AM
Rover-Fixer-Upper
area51Rover's Avatar
Quoted: 0 Post(s)
Wow, Same issues here!
Hi,
I had bought my (6 Disco 1 a year ago and did the brakes all round, (sandblast and paint calipers with new pistons and seals, new lines, rotors) Brake system was empty for a few months.
They were good at first, then one day I ran the resevoir dry cause of a loose bleeder screw. now they are just spongie, it sucks. Bled them several times with no air coming out, still spongy. I may try the Master cyl.
Rob
"DIY I always say!"
area51Rover is offline
post #8 of 8 (permalink) Old 01-04-2011, 05:38 AM
Administrator
Quoted: 5 Post(s)
How exactly did you bleed them and how much DOT 4 did you use?
Need Parts?
Lucky8,
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
The E-Brake Ollie Discovery Series II 6 03-01-2009 08:28 AM
E-Brake help!! natvboy Discovery Series I 2 09-12-2007 09:14 AM
Brake ?'s Scott_97 Discovery Series I 4 09-07-2007 06:48 AM
Brake HELP!! ChuckD Discovery Series II 2 12-12-2006 01:08 PM
Any tips for adding Extended brake lines....(brake fluid bleed tips) keptin Discovery Series II 1 01-10-2006 08:27 PM
You may post new threads
You may post replies
