While it is true that a simple switch on the brake pedal determines if the brake lights are on or off, all that switch does is complete a negative ground to the BCU, which then provides a power feed to the brake lights. Probably when the HDC system is active, the BCU ´knows´this. When the system applies the brakes itself, it could also complete a negative ground to the BCU, which would then turn on the brakelights for the duration of the ground. This is my speculation on how it would work, if it does.
Current:
2005 Land Rover LR3 V8 SE w/ factory winch
Also current:
1995 Mercedes-Benz E320 Wagon
2002 Volkswagen Eurovan GLS
1996 Ford Explorer LTD 2WD
Previous Rovers:
1995 Range Rover 4.0SE (see avatar, driving during local flood)
